Spark Plugs
Old Apr 10, 2007 | 11:11 AM
Kid 67y's Avatar
Kid 67y
Spark Plugs
Thought I would get everyone's opinion on a preferenc on Spark Plugs. I've got a 90 2.9 Ford Ranger and not sure if it much matters. But, any additional advice would be helpful. Thanks everyone.
Old Apr 10, 2007 | 11:32 AM
pfogle's Avatar
pfogle
MOTORCRAFT plugs, NOTHING else. I've heard NGKs are good (works well in the lawn mower anyway), but for the best performance and mileage use what the factory did. The aftermarket plugs are usually hotter or colder making the engine run either rich or lean.
Old Apr 10, 2007 | 06:11 PM
rubydist's Avatar
rubydist
For the record, hotter or colder plugs will not make the engine run rich or lean. Plugs that are too hot will potentially cause detonation which can cause serious engine damage. Plugs that are too cold will foul, wasting gas and causing problems with passing your emissions tests if you have to do that.
I've had good luck with Motorcraft and Autolite in Ford engines. I just put some NGK iridium in my 4.0, so after a while I'll have some feedback on those.
Old Apr 10, 2007 | 11:17 PM
Level2's Avatar
Level2
Denso Iridium plugs are supposed to be good but I have no personal experience with them. Motorcraft or Autolite will work since Autolite makes the plugs for Motorcraft anyway.
Old Apr 11, 2007 | 05:28 AM
wendell borror's Avatar
wendell borror
You could try motorcraft, or maybe motorcraft, then there's allways motorcraft, if all else fails, try a set of motorcraft, if nothing else, try motorcraft hee hee!!!!
Seriously, it's hard to beat motorcraft or autolite in the newer fords, thier a perfect match. I've heard alot of people say that bosh don't take well in a ford. I bought a set of those splitefires once, that was a waste of money. Back in the old days, champion was a good ford plug, but not so anymore from what I hear. MC and autolite do a great job at a decent price, you won't go wrong there. I've been using MC or autolite all my driving life for the most part amd I'm well pleased with thier performance and durability.
Old Apr 11, 2007 | 09:18 AM
Kid 67y's Avatar
Kid 67y
I just want to say Thanks for everyones thoughts on this subject and others I've posted on here. For a novice mechanic it's a great spot to bounce q's off of ya'll and it has helped my learning curve. I appreciate all the information and help.
Old Apr 11, 2007 | 09:36 AM
wendell borror
Yeah, it is a great site, not only to learn from, it can also be relaxing after a hard day. You even start to build relationships after a while. I look foreward to just BSing with my friends everyday and hopefully people are helped a long the way.
ccd1977
27
Jan 15, 2013 09:24 PM
Greenford100
15
May 30, 2011 11:44 PM
YO MUDA
18
Nov 1, 2009 06:37 PM
Brandon350
Modular V10 (6.8l)
Oct 24, 2008 10:29 PM
flat black beast
Mar 26, 2004 06:37 PM
