1978 - 1996 Big Bronco
Mass Air Conversion
Old Nov 28, 2001 | 08:31 AM
Gates's Avatar
Gates
Mass Air Conversion
During this summer I swap out my tired old 302 for a 306 I built with a health cam and heads. I am also installed headers and a nice cat back system, reworked the EFI manifold and went from a 5 speed Mazda to a C6 transmission. I have about 3000 miles on the motor so far and everything seems to run well. Except for Idle. It is in desperate need of a Mass Air Conversion Kit.
I have been looking at the FRPP Kit. So far I have found it for 619 dollars. Where is the cheapest some one has gotten the kit for? Where did you get the kit from? Has anyone done this swap with Salvage yard parts? If so what is needed and involved in the swap.
Thanks for your help
Corey
Old Nov 29, 2001 | 07:00 PM
AlM's Avatar
AlM
Post Mass Air Conversion
[updated:LAST EDITED ON 29-Nov-01 AT 08:01 PM (EST)]I posted this awhile ago for another dude:
the 2001 Ford Racing catalog ($5.00) lists this kit for both manual, AOD and E4OD trucks/broncos from 87 to 93s; w/5.8'..5.0's..etc
http://www.fordracing.com/performanceparts/
truck/bronco kit includes:
eec-iv:
mass air proc. module assy
jumper wire harness w/sefi engine overlay
maf sensor w/air box lid, hoses, clamps
Ford says: "-Converts production "speed density" system to "mass airflow" system which directly measures engine airflow and supports engine modifications.
-This kit is required before making ANY performance modifications to engine and powertrain of EFI trucks. Some California trucks have mass air. NOTE: Designed for 1-5-4-2-6-3-7-8 firing order.
*Not legal for sale or use on pollution-controlled motor vehicles."
..notes that you have to call ford tech "hot line" for 5.8 instructions (think it's initially set-up for 5.0 firing order)
cost is:
$675.00 for manual..pn M-9000-T50 (5.0..ask for 5.8 info)
$750.00 for auto...pn M-9000-T51 AOD only (5.0..ask for 5.8/..and E4OD info..if applicable)
tech line is: 810-468 1356
and call Down's Ford for a price too!
732.349.2240
http://www.thefordsource.com/store/motorsports/electronics.htm
here is the link w/a pic:
https://www.ford-trucks.com/dcforum/bigbronco/1216.html
"honney" also posted :Pro-Flow has a kit too
Old Jan 16, 2002 | 07:07 PM
Lambo_3's Avatar
Lambo_3
Would this upgrade offer any benefit to a stock 91 Bronco 302?
Old Jan 16, 2002 | 07:26 PM
Mil1ion's Avatar
Mil1ion
Mass Air Conversion
