Need help configuring a new Super duty
Now for the trailer. Occasionally I will pull a 20,000 pound trailer where 3/4's of the weight will be on the gooseneck hitch because of the required axle configuration. And, on occasion, this trailer gets pulled offroad.
If you were I, and you could spec out either a 2008 F-250 or 350 (no duals) SWB 4x4 crew cab, what would you include to give it HD carrying capacity and 4x4 performance? I spec'd one out earlier and included the 3.73 limited slip rear, camper package, traction control (this wasn't available in '04). Have I left anything out? I spec'd an F-350 too and it was actually a couple hundred cheaper. Both with the 6.4l PSD and I left off the offroad package because skid plates don't interest me, nor does the stiff ride of those shocks. With the miles I have to put on a year, ride is the most important factor before pulling. If you had to pull a trailer that had nearly 15,000lbs in the rear end, what sort of suspension addons would you consider? I will never consider adding more leaf springs because my back cant take the ride when empty anymore. Thanks in advance for all your input. I get to have some say in the specs of this truck (not the purchasing guy) and I want to get it right.
The Ford ESOF (Electronic Shift-On-the-Fly) system is proven to NOT be reliable. 95% of the time when there are 4x4 engagement problems, its the front 'Auto'/'Lock' hubs that have failed. The transfer case motor usually does not give any problems. The hubs can fail for several reasons. Check vacuum lines. Could have dirt in the hubs. The dash '4x4' & '4x4 LOW' lights are only activated by the mode the transfer case is in, does not determine what the front hubs are doing. No sensors in the front hubs to give you or your truck feedback info. You must get out and put the front hubs in 'Lock' position when needing 4x4. When ordering a new truck, I would avoid getting the ESOF system and go for the reliable manual floor shifter and manual 'Lock'/'Unlock' front hubs. It sucks to go out into the mud or snow to lock the hubs, but at least you know the 4x4 system will work.
If I were you, (pulling 15,000-20,000# trailer) I would get an F-350, 6.4L diesel, 4.30:1 limited slip rear gears, slide in camper certification pkg (aux springs are not touching when empty, so not a rough ride), trailer hitch, trailer tow mirrors, & TowCommand TBC (Trailer Brake Controller).
