newbe needs help
Old Apr 9, 2007 | 09:28 PM
01 f-350 dually's Avatar
01 f-350 dually
newbe needs help
I want to make my truck Fast, But I'm new to the 7.3 PSD. I already have the Exhaust, the chip, the Gauges, the tractor filter, but its not enough. What else can I do fairly cheap to help with the Performance?
Old Apr 9, 2007 | 09:34 PM
Tenn01PSD350's Avatar
Tenn01PSD350
What chip do you have? Do you have any tranny mods?
Old Apr 9, 2007 | 09:38 PM
01 f-350 dually
no tranny mods since I'm on my third one in a year and a half. "Bad tranny shop"
Old Apr 9, 2007 | 09:40 PM
01 f-350 dually
the chip is a bully dog 6- position?
Old Apr 9, 2007 | 10:07 PM
Tenn01PSD350
Put your truck info into a signature. I have a TS 6 pos chip, not unlike your BD. Mine could go faster and run better with a DP chip tuned for the BTS valve body mod.
Old Apr 9, 2007 | 10:13 PM
CSIPSD's Avatar
CSIPSD
A new chip will help a little, but nothing you will be impressed with. What will impress you is that it will shift better, sound better, run cooler and get better MPG... Look up www.elite-diesel.com or www.dp-tuner.com for two of the very best tuners in the market.
Your next step is going to get expensive. There are alot of little mods you can do that will help, but nothing more then a few HP... Zoodad, Fuel pressure shiming, Intake air heater delete, CCV mod, there are lots of others...
Injectors, dual Hpops, bigger turbos... those are going to be your next HP gains.
Old Apr 9, 2007 | 10:19 PM
01 f-350 dually
one thing I noticed is that it doesnt smoke like alot of the other trucks Ive seen.
Old Apr 9, 2007 | 10:22 PM
CSIPSD's Avatar
CSIPSD
What are your EGT's at WOT? Boost numbers?
Old Apr 9, 2007 | 10:24 PM
01 f-350 dually
On the floor about 21-22?
01 f-350 dually
exhaut is about 9-10 max
Old Apr 9, 2007 | 10:33 PM
CSIPSD's Avatar
CSIPSD
Where is your EGT probe? In the down pipe (after turbo) or in the manifold (pre turbo)? Your Egt's sound low for pre turbo. Could be a fuel issue.
Old Apr 9, 2007 | 10:35 PM
01 f-350 dually
I think it pre turbo? it was there when i bought the truck
Old Apr 9, 2007 | 10:40 PM
CSIPSD's Avatar
CSIPSD
Look at the drivers side Exhaust manifold from under the truck. Or on the down pipe, just after the turbo.
See what happens if you take the red line from the wastegate (on the top back side of the turbo) unhook it from the turbo and plug it on to one of the bolt heads on the intercooler tubes. See if your boost goes up from there.
Old Apr 9, 2007 | 10:41 PM
01 f-350 dually
thanks i'll try that
