pics of lowered 67-72 ford trucks?
  #481
Old 08-08-2016, 06:17 AM
mhrmike's Avatar
mhrmike
mhrmike is offline
  #482
Old 10-12-2016, 05:35 PM
XLTRat's Avatar
XLTRat
XLTRat is offline
Uni Moe, that truck is beautiful! Well done! Couple questions. Are those Torque Thrust wheels clear coated? Or do you have to keep the rim polished? Also are the front springs stock/original? Cut? Did you use shackles and hangers in the rear? Love the stance. Hope to copy that when I do the suspension on mine. Any details/tips you can give would greatly appreciated.
  #483
Old 10-12-2016, 05:41 PM
psukraw's Avatar
psukraw
psukraw is offline
This thread is providing me with a TON of motivation! Nice work everyone!
  #484
Old 10-12-2016, 06:29 PM
spdcat72's Avatar
spdcat72
spdcat72 is offline
DJM beams, hangers and shackles.
  #485
Old 10-13-2016, 12:07 AM
Uni Moe's Avatar
Uni Moe
Uni Moe is offline
Thanks XLTrat. The rims are clear coated. Just soap and water to clean up. I used the DJM drop beams in front and their drop shackles in back. One of my original front springs was broken so I replaced them with stock springs from my 73 F150 parts truck which appeared to be a bit heavier. I did cut about 3/4 of a coil from the springs but my goal was too correct the caster. The only way to adjust caster is by cutting or shimming the coils because you can't bend DJM beams. I only took 1/4 off at a time. A word of caution though. If you use new springs you might want to wait for them to settle a bit. Also if you tighten all the suspension components with the wheels hanging it will also sit a little high until it settles down. I was told the proper way is to tighten everything with the weight sitting on the wheels.
  #486
Old 10-13-2016, 06:45 AM
XLTRat's Avatar
XLTRat
XLTRat is offline
Thanks Moe, that helps me a lot.
  #487
Old 10-13-2016, 06:47 AM
f100today's Avatar
f100today
f100today is offline
  #488
Old 10-14-2016, 09:54 AM
Hackster1's Avatar
Hackster1
Hackster1 is offline
F100today.....its just so bad ***. You nailed a lot of stuff on that truck just right. But the stance, frontend, wheel and tire combo are just outstanding in my opinion. Too many people opt for the wrong wheels/tires. not just the style but the size, backspacing and tire size.
Congrats on the build, now finish up those little details and drive the **** out of it!!!
Sean
  #489
Old 10-15-2016, 08:03 AM
f100today's Avatar
f100today
Sean
Thanks Sean, I plan on doing exactly what you said, just not to the extremes you take yours to on the driving part. LOL
  #490
Old 10-21-2016, 11:17 PM
nevaplayedk9's Avatar
nevaplayedk9
nevaplayedk9 is offline
went ahead and did the axle flip
  #491
Old 10-30-2016, 09:04 AM
lilorbie's Avatar
lilorbie
lilorbie is offline
last weekend i went to a local swap meet. only 3 people selling ,but they are trying to get a swap going so not really to bad i guess. they did not charge for entry, or for a space. on the way back to the house i see on the right side of the road a crew cab bump. it looked like it had some kind of home made wrecker setup. of course where is my camera ? at the house!!!! some will say if there are no pics. it did not happen well it did happen. i would have used my cell camera but the lens is so scratched up you could not use it. i am thinking that it must be at least a 3/4 ton.they seemed to have a lot of other cars,trucks in the yard. not sure if they are into selling. what would be a ballpark figure for something like that? taking into account that the rust would be in all of the usual places? i could scrap the flat bed setup. thanks for any input on this.
  #492
Old 10-30-2016, 11:35 AM
f100today's Avatar
f100today
Was it lowered?
  #493
Old 10-30-2016, 02:15 PM
ceetwarrior's Avatar
ceetwarrior
ceetwarrior is offline
Originally Posted by f100today
Was it lowered?
LMAO, I thinking the same thing.
  #494
Old 02-09-2017, 08:38 PM
Jim Matthews's Avatar
Jim Matthews
Jim Matthews is offline
Originally Posted by nevaplayedk9
thats exactly what im going for....I just ordered the DJM kit today.
what shocks are you using
  #495
Old 03-07-2017, 03:15 PM
Sixtiesmusclecarguy's Avatar
Sixtiesmusclecarguy
Sixtiesmusclecarguy is offline
Another newer couple of Shots Of my Lowered "Shop Truck". Djm Beams,Shackle kit & Removed Two leaves & -1 Coil......
Quick Reply: pics of lowered 67-72 ford trucks?
