Drive train diagnostic help - please?
Old Apr 9, 2007 | 05:22 PM
emptyd's Avatar
emptyd
Question Drive train diagnostic help - please?
'01 X V10 w/ 104k & 3.73 LS rear diff.
Symptom 1:
Single “clunk” on final stop and first acceleration – probably from an under lubed slip yoke. Can't break the bolts loose to find out!?!
Symptom 2:
Leaking rear diff. seal (Pinion seal? Where the drive shaft enters the rear diff.) – replaced at dealership.
Symptom 3:
Very fine metal particles in rear diff. fluid.
Symptom 4:
Scoring or abrasions (very fine, almost like they were machined in) on metal surface next to the ring gear in rear diff. (clutch pack for limited slip diff.?) apparently from the teeth on the “worm gear” (right term? Gear on the end of the drive shaft inside the rear diff.). I have some pictures I'm trying to get from a friend to show what it looks like.
Possible conclusion: Slip yoke is so under lubed that the friction from suspension rise and fall is actually pushing the drive shaft into the rear diff. resulting in damage to the rear pinion seal and the contact between the worm gear and the clutch pack.
What do you all think?
Old Apr 9, 2007 | 07:05 PM
Monsta's Avatar
Monsta
Sit. Stay.
It's possible I suppose. I don't think that the pinion has the ability to go back any farther in the housing though. I can see the pinion SEAL going bad becuase of the poor movement of the slip yoke though.
Drop the shaft (make sure your parking brakes are on!!) and lube the yoke and take it from there. I would also replace the diff' fluid if you haven't already. Drive it for 500 miles or so and then have another look-see.
Old Apr 9, 2007 | 07:44 PM
emptyd's Avatar
emptyd
I can't drop the shaft! I imagine the dealer had to do this to replace the seal but I can't break the bolts free. They are those strange twelve point bolts that round off easily. I guess it's time to start soaking them in deep creep.
I did replace the diff. lube. Good point about rechecking it in 500 miles.
If the pinion can't be forced deeper into the diff., then what is causing the pinion gear (worm gear?) to rub against the clutch pack body?!?
Thanks for the suggestions, as always you're a big help Monsta.
Old Apr 13, 2007 | 11:31 AM
dkadr316's Avatar
dkadr316
you have to use heat to break the thread lock
Old Apr 13, 2007 | 11:32 AM
dkadr316's Avatar
dkadr316
use a 12 pnt socket
Snakeoiljoe
May 23, 2016 06:40 PM
nvrsadi
May 17, 2016 05:19 PM
Colorado Highboy
Mar 21, 2016 03:13 PM
p61sam
1983 - 2012 Ranger & B-Series
Jul 1, 2014 09:00 PM
F-erOnlyRunsDwnhill
Apr 11, 2014 09:20 PM
