1978 - 1996 Big Bronco
oil for power steering
Old Jan 16, 2002 | 04:18 PM
8996EBBroncos's Avatar
8996EBBroncos
Old Jan 23, 2002 | 02:02 AM
hermann's Avatar
hermann
Can I fill an normal ATF Oil in my powersteering?
Or must I´ve a special oil. Ford recommended an ATF Type "F"
Is this the same as the ATF for transmission?
Thank you
Old Jan 23, 2002 | 09:36 AM
thelonerangerxlt's Avatar
thelonerangerxlt
Ford Type F automatic transmission fluid is what Ford recommended for the older power steering pumps. Rumor has it, that Ford did not want to stock two similar fluids at the factorys, and that is why they used their Type F, instead of another power steering fluid.
You can use the Type F if you can find it. I would not use the Mercon/Dexron. You can also use regular power steering fluid in it.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
