Aerostar Ford Aerostar
94 Vacuum system.
Old Apr 9, 2007 | 03:21 PM
media's Avatar
media
Question 94 Vacuum system.
Howdy!
I bought a 94 4WD Aerostar from an auction at the beginning of last month. I had to replace the front CV joins (pain in the butt), but I still have another issue haunting my van. It's been happening since I bought it. The van sputters, surges and/or tries to die when it's idling. It is the worst when you have the van in gear (automatic) and the foot-brake applied (waiting for a red light to change). If you put the van into Park, it's much less noticeable (waiting for the drive-throu line at McDonald's to move). Once you start to apply the accelerator the surging goes away and the van runs great (fleeing with the extra BigMac they gave you by mistake). I've tried injector cleaner, gas treatment additives and nothing has fixed this problem. Then about two weeks ago I noticed a pop, hiss then very little brakes. The vacuum hose for the brake booster popped off. When I went to put it back on I noticed that the vacuum hose for the Cruse Control wasn't plugged in either. However there was only one free **** to put a hose onto. I weighed in my head that brakes are more important then being able to cruse, so the cruse-control is still disconnected. That got me to thinking that the surging issue maybe vacuum related, but I have not been able to find a diagram or another vehicle that I can look at to see where all the vacuum hoses go.
Can someone please link or post a diagram of the vacuum hose system for the 94 4wd Aerostar?
media.
Old Apr 9, 2007 | 03:33 PM
Mormakil's Avatar
Mormakil
3.0 or 4.0??? I posted the 3.0 diagram a couple of months ago...
M
Old Apr 9, 2007 | 03:48 PM
media's Avatar
media
Hermmm, I am thinking it's the 3.0 if I remember correctly. I'll have a look tonight to make sure.
media.
/edit/
I had a look at the diagram you posted. (please forgive the novice questions, I am not a mechanic). I didn't see any mention of the vac-hoses for the cruse-control or brake booster. Is there a diagram that shows where those go, if they are supposed to have their own nipple to connect to the main cylinder and if they are supposed to be branched off the two nipples that are availible (that I can see) via a "T" or "Y" connector? (there is a thrid vac-hose that is connected to a second nipple, but I am not sure what it's connected to).
media
Old Apr 9, 2007 | 04:12 PM
merlynr's Avatar
merlynr
Question
I thought all extended 4wd were 4.0 or am I making this up?
Old Apr 9, 2007 | 04:19 PM
copper_90680's Avatar
copper_90680
Hi Media:
Welcome to our FTE forum
Merlynr:
There is a very small number of 3.0L AWD, almost zero. So you are right, if it an AWD, it's most likely a 4.0L.
Old Apr 9, 2007 | 04:28 PM
media's Avatar
media
I thought it was a 4.0 at first, but then I asked my GF's dad (he is the ford fixer guy), and he figured it was a 3.0. Ill check the stickers (if I can read them) to make sure.
media.
Originally Posted by copper_90680
Hi Media:
Merlynr:
Thank you for the welcome, and I am 100% possitive its a AWD.
media.
Old Apr 9, 2007 | 04:44 PM
96_4wdr's Avatar
96_4wdr
what's the VIN X marks the 4L spot
look on underside of hood and top of sheet metal in front of radiator by hood latch for vacuum diagram
Old Apr 9, 2007 | 05:53 PM
merlynr's Avatar
merlynr
I went and looked at my son's 4.0 awd(lives next door) and there are 2 vac lines going to the cruise control. One comes from somewhere at rear of eng. and the other one seems to come thru the firewall near the brake booster. the one from the brake booster swoops down and goes back up to rear of engine also. didn't take the doghouse off (pia).
Old Apr 9, 2007 | 11:39 PM
Bear River's Avatar
Bear River
Former ******
Check the 8th digit of the vin code to confirm the engine.
Old Apr 10, 2007 | 01:16 PM
media's Avatar
media
It's a 4.0L engine, the sticker on the underside of the hood said so. I also saw the vacuum diagram however it only shows the brakebooster vac-line coming from the back of the engine. The cruise control wasn't shown anywhere on the diagram.
So I still have a cruise control vac line with no home.
media.
Old Apr 10, 2007 | 10:02 PM
96_4wdr's Avatar
96_4wdr
cruise aka speed control vac. line is black/brown goes to vac. distribution block on back of manifold...access thru dog hatch inside...rib buster and knuckle skin remover...take off RABS controller on bottom of dash center
brake booster, heater vac cont., tranny vac. mod. also run to same dist. block
