Van will not Turn Over..
Old Apr 9, 2007 | 11:27 AM
cheetoh's Avatar
cheetoh
What would Cause the Engine not to turn over on My Van? The Battery is Charged, It has a New Starter, New Solinoid, new Ignition Switch, but when You turn the Key, Nothing Happens!! I can Hear the Fuel Pump Start and that is It. Any ideas??
Old Apr 9, 2007 | 11:43 AM
pfogle's Avatar
pfogle
What year, what engine? That will help, if it's a pre '93 E250 or E350, or a pre '92 E150 then it has an adjustable ignition switch. The key may be turning but the switch may not be traveling to the correct spot.
Old Apr 9, 2007 | 11:47 AM
cheetoh's Avatar
cheetoh
It's a 1991 e150. 5.0 liter engine.
Old Apr 9, 2007 | 12:02 PM
pfogle's Avatar
pfogle
Ok, the switch has elongated holes in it. Try setting the switch right dead in the middle and see what happens. If that fails call a buddy or your wife and have them help. Grab a test light and pull the wire off the "S" (should be a single wire with a rubber boot on one small terminal) and see if you have power there when the key is in the "START" position.
Old Apr 9, 2007 | 08:24 PM
mhg's Avatar
mhg
jump 12 volts to to the s terminal
if it starts then the problem is in the switch system
including the neutral saftey switch
Old Jun 3, 2007 | 06:24 PM
cheetoh's Avatar
cheetoh
It ended up being a rod in the steering Column itsself, Cheap Part, Expensive labor, Steering Column had to be taken completely apart.
Old Jun 3, 2007 | 07:05 PM
Jimbare's Avatar
Jimbare
all alone in the world
that sucks dont it. 2.00 dollar part, 200.00 labor!
