Check Engine Light On Solid And Running Badddd
Old Apr 9, 2007 | 11:10 AM
JTP0110's Avatar
JTP0110
After Warming My 02 7.3 Diesel The Check Engine Light Came On And When It Shifts Into O.d. The Truck Shakes But The Engine Does Not Smoke. It Still Does It With O.d. Off...any Thoughts????
Old Apr 9, 2007 | 11:48 AM
clintbonnie's Avatar
clintbonnie
You should read your fault codes..Great help on figuring out whats going on.. Does it run smooth at a idle?
Old Apr 9, 2007 | 11:53 AM
never2big's Avatar
never2big
Is it bone stock? If you had a tuner, it would be very helpful to pull your codes off.
Old Apr 9, 2007 | 01:38 PM
wlihntr's Avatar
wlihntr
many times, with those symtoms, you have something wrong under one of the valve covers. most likely the UVC (under valve cover) plug has worked loose but it could also be a chaffed wire on the UVC harness. the easiest way to check is to start the truck and unplug each of the outside VC plugs (push down on the top and pull) one at a time. if you unplug one and the truck runs worse or dies...its not that side. if you unplug it and nothing happens...than its something with that side.
Old Apr 9, 2007 | 01:46 PM
John311t's Avatar
John311t
I bet it pulls a 1316, which means IDM code stored, which probably means UVC harness connection issue. Either that or it will throw a code for contribution issue. Get codes read.
423billyc
May 16, 2013 06:35 AM
clouden
Sep 2, 2010 09:21 PM
creolex
Sep 8, 2006 09:33 AM
