removing seized calipers
Old Apr 9, 2007 | 10:55 AM
henry1976's Avatar
henry1976
apparently my front disc brakes have locked up. I dont know why or how to get them off. Anyone know what might cause this to happen? where to I begin to take them off?
76 f150 360 2wd.
Old Apr 9, 2007 | 02:21 PM
1pump's Avatar
1pump
Both of them? That seems unlikely, unless your master cylinder or porportioning valve is stuck somehow.
If it's a caliper, then the piston's seized up. That used to happen quite a bit back in the days before they had silicone brake fluid.
If it were me, I'd try opening the bleeder screw and forcing the piston back. If that was a no go, I'd unhook the hose and caliper hardware and take the hub/rotor off with the caliper stuck to it. At least that way you'd be able to knock it off of there.
Old Apr 9, 2007 | 02:47 PM
Mil1ion's Avatar
Mil1ion
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Old Apr 9, 2007 | 04:27 PM
firstonraceday's Avatar
firstonraceday
The rubber brake lines can get weak over time and collapse internally thereby keeping pressure on the pistons in the caliper. Once you get the old calipers off, might as well replace the calipers and rubber brake lines.
Old Apr 13, 2007 | 10:32 AM
henry1976's Avatar
henry1976
Thanks. My mechanic mentioned that as a possibility as well. The master cylinder is about 6 or 7 years old. Dont know about the calipers age. They look a little rusty even though the truck hasnt seen water in a long time. I heard they are prone to rusting and having the caliper stick once the piston releases. I guess I am going to get fluid, a line for each side, and two new calipers and see where it goes. Unless anyone has a better suggestion.
When you are talking about the lines are you referring to the line that goes from the caliper to a bracket or something and is about 13 or 14 inches long? That line looks pretty old.
Old Apr 13, 2007 | 12:47 PM
firstonraceday
I believe we are talking about the same lines, the ones from the caliper back to the steel lines. I had a similar situation on my 77, the rubber lines were original. I had not been keeping an eye on them as well as I should. I suspect the lines collapsed and in a worst case scenario (mine) the constant pressure leads to premature pad wear and rotor scoring. I ended up replacing one rotor along with both calipers and brake lines.
Old Apr 13, 2007 | 01:32 PM
henry1976's Avatar
henry1976
do you recommend a place to get the calipers and lines? autozone, oreilly, napa? cost?
Old Apr 13, 2007 | 01:39 PM
firstonraceday
I got mine at O'Reilly. My local store seems to have more of the parts for older trucks in stock, along with a wider selection of Motorcraft parts for tuneups, etc.
Cost wasn't bad, seems like around $16.00 each for the reman caliper and $12.00 each for the brake lines. This is for an F-250 with single piston calipers.
Old Apr 13, 2007 | 07:56 PM
Mil1ion's Avatar
Mil1ion
I prefer Wagner and Raybestos Brake parts
EIS.... if I'm in a jam.
Old Apr 13, 2007 | 09:02 PM
Ranger73's Avatar
Ranger73
did u get em off yet.
Old Apr 13, 2007 | 11:21 PM
rusty7983's Avatar
rusty7983
i'm in the same situation with my f350. only i just bought it. my wife says can we return it? so i'm into it for about 300 so far. should be done tommorrow. i hope.
Old May 7, 2007 | 11:04 AM
henry1976's Avatar
henry1976
attempt #1
replaced the calipers and tried to replace the brake lines from caliper back to the truck. Driver side line... the hard line fitting i think stripped while half way screwed into the new line that goes back to the caliper. cant get any pressure because it isnt tight and it wont back out, just spins. What do I do?
Old May 7, 2007 | 12:44 PM
Mil1ion's Avatar
Mil1ion
Can you post a pic so we know exactly what we're dealing with?
Old May 7, 2007 | 01:49 PM
henry1976's Avatar
henry1976
i will try and get a pic tonight.
Old May 7, 2007 | 09:13 PM
rusty7983's Avatar
rusty7983
try to put some pressure on them while loosening. pull with a little pressure while loosening them up. sometimes i've used one finger to spin the wrench and the rest to pull apart. it usually doesn't take much pressure.
