Have a 86 F-350 2wd dually 6.9l 4spd 235/85/16 tires. Currently runs 2200-2300 at 55mph. Would love to have her run 2200-2300 near 65-68 mph. Basically looking for better fuel mileage. Can someone give me an idea of what gear ratio I need? Also whats the best place to buy the gear set, I'll install them myself. Thanks
A ZF5 from an 87'-95' F250/350 would be the way to go. Unfortunately that switch won't be cheap. The ZF5 will bolt to your 6.9l motor, but you will need a new clutch along with the ZF5 tranny. Even if you do all the work yourself, you probably are still looking at spending somewhere between $3,000 and $5,000 in parts. ZF5 trannies are also hard to come by as they are quite popular and are a good tranny unless you totally abused them.
I am assuming you got a standard, if your truck is an automatic then the conversion to a ZF5 would be even more costly.
Refer to the attached web page for more details on the ZF5:
Never took the time to look at what gears are already in the truck. Quess I figured to replace them no matter what they are. I'm a little concerned about power loss but I do my heavy pulling with my Freightliner, Cat diesel. My biggest complaint is screaming around town at 2300 rpm only going 55mph and the 10 mpg. First gear is almost worthless, I'm taking off in second 90% of the time. I've thought about the 5spd but $250 for a set of gears sounds like the way to go. But what ratio???
it would be my guess that you've got 510's in the rear end if you're running 55mph at 2200 rpm. i've got 410's in my '90 f-250 and am running 65 at 2150 to 2200 rpm. if that's the case that you've got bigger than 410's, i'd try to get some 355's. personally, i'd like the big gears and just go with taller tires, but don't think that's an option on dually...... but that's just a thought.
speedrdr
