Head Lamp assembly removal ?
Old Apr 9, 2007 | 08:45 AM
Mr Alias's Avatar
Mr Alias
I have a 1992 F150, 302 that I am striping for parts. I am trying to remove the headlamp assemblies and have run into a road block. I have removed the two upper top screws and have unscrewed the three adjustment screws as the book I’m using had instructed but still can not seem to get the assembly out. The upper to screws, which hold the plastic frame do not allow for the frame to be removed as it is also secured on the bottom which can not be accessed until the entire assembly is removed. What am I missing? Diagram would be most helpful on removal if anyone has one. I have used the program “ALLData” and the Ford CD Manuel and both of them are no help on removal. Great for taking out the bulbs but that’s it. Any help would be greatly appreciated.
Old Apr 9, 2007 | 08:51 AM
Conanski's Avatar
Conanski
There are 2 screws behind the rad support near the fenders, you have to pull the washer bottle or battery to get to these.. depending upon which side you are removing.
Old Apr 9, 2007 | 09:05 AM
quicklook2's Avatar
quicklook2
covered many time, like once a month.
do a search.
Old Apr 9, 2007 | 09:35 AM
Mr Alias's Avatar
Mr Alias
Thanks Conanski. I will take a look at this later today to see if that does the trick.
As for you quicklook2, perhaps you could give some helpful response rather than a sarcastic worthless response. FYI I did search just as the title is presented and found nothing close. Perhaps you could point me to one of these monthly posts that covers this seeing you know all about this. I also looked at a bunch of your replies and it appears you enjoy confrontation from others.
Old Apr 9, 2007 | 10:08 AM
subford's Avatar
subford
This one always comes up in a search.
https://www.ford-trucks.com/forums/4...sasembely.html
Old Apr 9, 2007 | 10:29 AM
Mr Alias's Avatar
Mr Alias
Yes it did, third page in on my third search. Thanks. Its a good post and helps alot. I'm not so sure the search function works real well.
Old Apr 9, 2007 | 10:36 AM
subford's Avatar
subford
I put the image back in at the end of the post.
Old Apr 9, 2007 | 11:04 AM
quicklook2's Avatar
quicklook2
to tell you to search was not sarcasm.
it was the way to get you the info you needed.
Old Apr 9, 2007 | 11:15 AM
subford's Avatar
subford
Hang in there. They come back and say that about me or that I get personal with them all the time.
Old Apr 9, 2007 | 11:50 AM
Scndsin's Avatar
Scndsin
Perhaps the gentlemen could author a thread or article on how to best phrase a search query. Especially for some of the more common, redundant or complicated questions that arise continuously?
I'd be most interested in how better to tap the info here.
Or perhaps sometimes just provide a link to a thread you have subscribed?
Old Apr 11, 2007 | 07:39 AM
Mr Alias's Avatar
Mr Alias
I would like to publicly apologize to quicklook2 for my comments above. They were uncalled for and inappropriate. His post was a suggestion that was designed to help and not be sarcastic as I first thought. I know better having been on many forms boards before and should never try to understand tone of a conversation based on a few words. He was right, the post I needed was found with a search and if I was a little more patient I would have found it. Please accept my apology and rest assured I will search with patients next time. Thanks.
Old Apr 11, 2007 | 08:02 AM
quicklook2's Avatar
quicklook2
we're cool.
when i posted to do a search i was trying to tell you it was covered so many times it would be easy for the search to find you an answer.
hope you got it fixed without much trouble.
serussell
Sep 4, 2016 08:58 AM
bstidham
Oct 4, 2015 03:20 AM
Bramage
Aug 28, 2015 05:37 PM
Thomas White
Jul 11, 2015 01:25 PM
phantomphixer
Apr 4, 2015 01:21 PM
