intercooler pipes
Old Apr 8, 2007 | 11:07 PM
matt95stroker's Avatar
matt95stroker
intercooler pipes
does anyone have a 6.0 intercooler installed? i need to know what to do about the pipes and boots. thanks a lot
-matt
Old Apr 8, 2007 | 11:10 PM
powerstroked162's Avatar
powerstroked162
Its alot of cutting and bending on the IC pipes. best bet is to have them bent up for ya by an Exhaust shop. And yes both the 7.3 and 6.0 IC's will fit. Good luck!
Cowboy Steve
Old Apr 8, 2007 | 11:13 PM
ForemanES's Avatar
ForemanES
The 7.3 superduty ic pipes can be used with only a few modifications. The only thing with the 6.0 is one end needs a bigger hose connection so you have to buy a reducer.
Old Apr 8, 2007 | 11:27 PM
ltfox's Avatar
ltfox
I got one on my 96. I bought the GTS kit to install it. As FormanES said the only thing the 6oh cooler needs different is a 3-3.25" boot for the one side. Ya can get it from Ford. Just specify that ya need a IC boot for the right(passanger) side for a 6oh powerstroke. If your 2wd the sway bar need to be moved also, but no trouble if your 4wd.
Old Apr 9, 2007 | 12:11 AM
matt95stroker
what kind of mods need to be done to the stock pipes
Old Apr 9, 2007 | 12:17 AM
RubberDuck's Avatar
RubberDuck
On mine I added 3" to the drivers side pipe at the turbo. The passenger side was a little more difficult. I used the stock pipe from the intake spider all teh way to the second bend. Then I used 2 3" 90* bends one long, one short to make an S to get it to the cooler and then welded the stock end on the last 90* bend. There are pictures and writeups in my gallery.
Old Apr 9, 2007 | 12:28 AM
matt95stroker
thanks a lot ill let you know how it all works out thanks again for the help
Old Apr 9, 2007 | 01:24 PM
FARM69's Avatar
FARM69
RubberDuck, does you hot side fit up perfectly with the 3 inch extension. I did mine that way and the pipe doesn't sit properly with the hoses. It's about an inch off.
Old Apr 9, 2007 | 09:39 PM
RubberDuck's Avatar
RubberDuck
It's not perfect, but it's pretty close. But I know what you are saying. I think my lack of being able to cut it straight with the chop saw saved me there. It looked pretty straight, but I think I just got lucky cause it fit's really good in my opinion. Most likely I cut it crooked, and got lucky when I welded it together. Because I wasn't looking for an angle IIRC.
