Sponsored by: Auxito
1997 Ford F150 Computer Problem? Help
Old Apr 8, 2007 | 01:10 PM
biglucky's Avatar
biglucky
I Have A 1997 F150. A Few Days Ago The Temp Guage Went Totally Down And Then Pegged And At The Same Time The Oil Light Came On. I Immediately Shut The Truck Off And Raised The Hood, Checked The Oil It Was Full And There Was No Signs Of Over Heating Problems. After Getting Back In The Truck And Starting It All Guages And The Truck Was Fine. This Has Happened About 3 Days In A Row. I Had Advance Hook Up Their Scanner And That Did No Good. But I Have Had A Couple Of People Say That Possibly The Engine Control Computer Was Going Bad. Any Help Or Ideas Would Be Greatly Appreciated. Thanks
Old Apr 8, 2007 | 05:22 PM
bosshoss's Avatar
bosshoss
We had one a while ago, that the battery went bad. It took out the alternator. I would have the battery & alternator tested on the truck first. Make sure you have good cable connections. Good luck
Dave P.
Old Apr 8, 2007 | 06:38 PM
projectSHO89's Avatar
projectSHO89
You do not have a computer problem. You have either a charging/power distribution fault or a flaky instrument cluster that is intermittent
Steve
Old Apr 8, 2007 | 08:08 PM
streethealer's Avatar
streethealer
Had an Explorer that the cluster would go nuts every time I got in it. Had the instrument cluster replaced and the problem was fixed..
MR6X6
Apr 28, 2015 02:21 PM
77429highboy
Aug 2, 2011 09:32 PM
brd7666
Jul 25, 2010 11:08 PM
bronco-man
Feb 24, 2008 05:56 PM
1993F150302
Mar 12, 2005 11:53 AM
