Offroad & 4x4
axle shaft replacement
Old Apr 8, 2007 | 12:44 AM
Dubzilla's Avatar
Dubzilla
So, my front passenger side axle shafts are mangled, the u-joint apparently exploded or something, because it's not there.
I ordered a new inner, outer, and u-joint, and i was wondering what kind of stuff i'd run into during the replacement process. seals, bearings, anything special i should check?
Also, it's been driven a bit with the shaft like that, but not in 4wd, and the inner shaft slid out a few inches. is this a sign of something broken or missing?
Also, if someone could explain to me, via reply or PM, what the point is of t-case doubling/twin-sticking, that'd be cool, i'm curious.
78 bronco, stock d44.
Old Apr 8, 2007 | 10:30 AM
75F350's Avatar
75F350
Inspect the area that the u-joint sits in. Often times the hole wil become damaged, or out of round. If it becomes egg shaped, or damaged, it will not place even pressure on the u-joint cap, and failure will be sooner than you know.
shore
May 8, 2013 07:09 PM
MontanaMan
Apr 27, 2009 08:03 AM
jkuelper
1983 - 2012 Ranger & B-Series
Mar 31, 2008 08:54 PM
fordor
Oct 22, 2006 11:41 AM
Taasman
Apr 24, 2004 04:43 PM
