headers for 5.0??
Old Apr 5, 2007 | 09:16 PM
wattsup's Avatar
wattsup
Question headers for 5.0??
hi, need some help here, I am in the middle of doing some motor work on my 91 f150 4x. While I am at it, was thinking of adding headers. how much difference would headers make on a stock 5.0 engine?
Old Apr 6, 2007 | 09:31 AM
lostin90s's Avatar
lostin90s
shorty's about 5-15hp according to posts. And long up to 20 hp 25 hp
The long tubes will help on bottom end grunt . I don't use them because I have trouble placing cat on drivers side . And don't like to run pipe lower than trans ( yes I've crushed some pipes as well as trans pan ) But performance wise they are way to go .
The shorty's are nice if you have emissions to go through. ( I've heard stories of people getting hassled about the cat not being in stock location .ETC) And you can use stock y pipe or get a performance 1 .
In my past truck I found that if I open up exhaust to much its bad for performance .
What ever route you thank get a good set. Or you will have flange and rust problems. Good luck
Old Apr 7, 2007 | 09:15 AM
mrl390's Avatar
mrl390
I have long tube headers on my 5.0. I could tell a difference but I dont know if it was because of the headers or because I got rid of the stock y pipe and went to duals. I do know they sound alot better and my truck doesnt seem to have to downshift as often when going up hills.
Old Apr 7, 2007 | 09:19 AM
efftwofiddy's Avatar
efftwofiddy
What kind of longtubes do you have? Where did you get them?
Old Apr 7, 2007 | 10:33 AM
Mr. M's Avatar
Mr. M
I'm happy with the Ford Motorsport Shorty headers. I also slapped in a bassani y pipe and cat. Passed emissions flawlessly and some solid power gains.
Old Apr 7, 2007 | 12:08 PM
lostin90s's Avatar
lostin90s
Just get a good set with think flanges . If you go cheap you will be changing out gaskets and having them rust on you good luck .
I have a set of Ford racing ceramic (look like chrome) coated shorty heads to mine if I ever get money to do exhaust.
Old Apr 7, 2007 | 01:29 PM
Mr. M's Avatar
Mr. M
[QUOTE=lostin90s]
The shorty's are nice if you have emissions to go through. ( I've heard stories of people getting hassled about the cat not being in stock location /QUOTE]
I've had this issue before for California and Washington state emissions. I passed both with flying colors, but the visual inspection can get hairy. They didn't believe I even had a catalytic converter since the 2 stock cats were removed and replaced by the bassani y pipe and cat. The new cat that comes with the bassani system is the size of a soup can. If they give you any issues about removing stock cats, tell them you tore up the stock system offroad. Thus, justifying a replacement. Don't tell them it was replaced for performance. That is illegal (CA and WA not sure about other states) if the stock cats are functional.
If you don't have a mig welding setup, pay the money to have an exhaust shop clean it up. It does wonders for the visual inspection, if needed.
Old Apr 7, 2007 | 03:51 PM
mrl390's Avatar
mrl390
I bought a set of summit racing long tubes, which actually turned out to be flowtechs. They only cost $125 and they fit no problem.
Old Apr 8, 2007 | 01:46 PM
wattsup's Avatar
wattsup
thanks for all the info. i like the idea of more low end grunt w/ the long tubes. been looking at some hookers.
In the process of pulling the heads at the moment so i have time to study this more.
