e85 fuel
Old Apr 7, 2007 | 02:59 PM
dpatterson2005's Avatar
dpatterson2005
Smile e85 fuel
what would need to be done to my 99 expedition so i can use this fuel thanks
Old Apr 7, 2007 | 07:59 PM
FTE Herman's Avatar
FTE Herman
I'd like to know this specifically too. I know one issue would likely be the injectors are too small to deliver enough fuel.
Old Apr 7, 2007 | 10:34 PM
projectSHO89's Avatar
projectSHO89
Trade it in for a new Flex-Fuel, if one is available...
Otherwise, you have issues with incompatible fuel system materials and a fuel delivery system that, in stock form, is inadequate to deliver sufficent corn-squeezins to properly run the engine.
Mixture concerns can be addresses by aftermarket injector pulse stretcher circuits, higher flow rate injectors, or custom PCM calibrations.
Steve
Old Apr 8, 2007 | 08:32 PM
c_hohensee's Avatar
c_hohensee
The shop that did my dyno and chip tuning does this. They change the injectors and put in a switchable chip so you can run on regular gas or
E85 with a flip of the switch. They claim to have figured out the tuning needed to make this work. They describe how they do this on their website www.hitechmotorsport.com
Old Apr 8, 2007 | 10:21 PM
bridge's Avatar
bridge
Sick 'n Tired
Changing engine parameters and fuel delivery is not a big problem to overcome. The problem is replacing all the alcohol incompatible materials within the engine and fuel system. Ethanol eats through rubber and certain plastics, albeit somewhat slowly. So, if your car has gaskets or seals made with an incompatible material...
My F150 is a flex fuel vehicle. We just got a new gas station around the corner from my house that has E85. I gave it a try because it is $.30 cheaper than unleaded. Unfortunately, E85 gas mileage is not so good. Normally my Screw goes ~325 miles on a tank. I'll be lucky to get 225 on the E85.
Old Apr 11, 2007 | 07:02 PM
dpatterson2005
thanks guys for all your information sounds like its not worth the cost again thanks
Old Apr 16, 2007 | 11:51 PM
MazdaRangerGuy's Avatar
MazdaRangerGuy
Basically you'll need higher flow injectors, and a sensor to determine the E85 content in the fuel. Also any non-alcohol compatible components need to be replaced.
As of right now, there are no EPA approved conversion kits available for this, as it's not cost-effective to do so, therefore no one is willing to invest in all the testing, etc, for this type of conversion.
Yes there are some tuning places that can make some modifications as C_Hohensee mentioned... but not many... like I said.. it's not real profitable right now except for very niche markets.. so it's not going to be commonplace for a long long time.
natew
Mar 7, 2015 10:16 AM
pile_53574
Wisconsin Chapter
Aug 19, 2007 07:23 PM
Deen Hylton
Jan 7, 2007 06:07 AM
sideout2
1978 - 1996 Big Bronco
Aug 24, 2002 11:27 PM
reberhardt
Jul 13, 2002 01:53 PM
