96 PSD fuel tank q's
dual tank setup, do these trucks have fuel pumps in the tank???? I have only been using the rear tank since i got the truck, because the front tank is hard to fuel up(takes forever). I am going to be fixing that this weekend so I'd like to make sure everything works in there before I go dumping a bunch of fuel in there. Guage seems to work like it should.
The way Ford designed (and it does not work right) the filler neck, the fuel goes into the tank thru the black inner tube and air (is supposed) to exit the tank around the outside of the tube.
Check this out to do "FIX" that works. https://www.ford-trucks.com/forums/5...4x4-cc-ps.html
I can fill up at the commercial pumps with them running wide open until almost full (about 1/2 to 1 gal from full).
tkisling
12-25-2013 09:47 AM
