Diff. Fluid
Old Apr 6, 2007 | 10:16 PM
Suber's Avatar
Suber
Diff. Fluid
Hey all, I am about to change my gearbox and front/rear diff fluids and would seek some feedback. I am not sold on synthetics but am open to ideas. I have mostly stuck with Valvoline in the past. Fire away!!
Old Apr 6, 2007 | 11:29 PM
RubberDuck's Avatar
RubberDuck
Amsoil ATF in the 5speed or Auto Amsoil 75w-140 in the diffs and don't forget about the limited slip additive. That's what I run and love it. Alot of the guys on here like the Royal Purple which also is excellent, or Redline which is very good as well. Basicly it comes down to personal preference.
Old Apr 7, 2007 | 02:52 AM
audimaster's Avatar
audimaster
I've been searching much on this topic
the 75-140 weight or 75-90 weight, and the synthetic vs. dino. I finally just went with 75-90 synthetic for the best of both worlds.
Old Apr 7, 2007 | 10:44 AM
Suber's Avatar
Suber
I am wondering if I have a posi rear-end, or slip on my 1-ton. I am not sure. I am told you have to put an additive in if it is a posi-trac rear-end.
Old Apr 7, 2007 | 10:56 AM
Cuda_jim's Avatar
Cuda_jim
Lift both rear wheels off the ground, put the tranny in 'N', spin one tire, if the other spins in the same direction you have Posi, If it goes in the opposite direction, ot doesn't move you have an open diff.
75-140 syn has the posi additive in it but you still need to add 4-8 oz's. IMO.
Check the tags on the outside of the diff cover. Post the #'s here for de-coding.
Old Apr 7, 2007 | 01:24 PM
Suber's Avatar
Suber
The tag info is as follows:
S 132 P
4L10 10 2 7L07
Old Apr 7, 2007 | 02:01 PM
tjbeggs's Avatar
tjbeggs
you have limited slip 4.10 gears
Old Apr 7, 2007 | 03:12 PM
Suber's Avatar
Suber
Thank you Sir!!
Texas Bob
Oct 19, 2019 12:12 AM
Texas Bob
Jun 16, 2012 02:52 PM
Angrywasp
Aug 8, 2011 09:00 PM
Rotterdam24
Aug 27, 2010 03:02 PM
fearfactory
Oil & Lubrication
Mar 30, 2006 11:15 AM
