code troubles
Old Apr 6, 2007 | 08:38 PM
expo1's Avatar
expo1
Unhappy code troubles
lets see I have a 98 explorer E/B, 4.0 sohc with codes P0301, P0304, and P0171. just replaced all plugs and wires with motorcraft, installed new intake gaskets upper and lower, cleaned the maf and iac, and still getting the same three codes any ideas? thanks in advance, matt.
Old Apr 7, 2007 | 10:14 AM
Mel902's Avatar
Mel902
Well the P0301 is Cyl #1 misfire,P0304 isCyl#4 misfire and P0171 is System Adaptive fuel is to lean(Bank1), don't know if it helps but good luck.
Old Apr 7, 2007 | 05:05 PM
aquanaut20's Avatar
aquanaut20
Make sure you have now crossed the plug wires.
Old Apr 7, 2007 | 06:11 PM
Mel902's Avatar
Mel902
Yes it might be 1 &4 crossed and that is why it is getting the misfire.
Old Apr 7, 2007 | 09:47 PM
expo1's Avatar
expo1
what is the firing order 1,4,2 5,3,6 or 1,3,2 5,4,6
Old Apr 7, 2007 | 10:11 PM
aquanaut20's Avatar
aquanaut20
Have to go consult my manual, for your vehicle, I am not home so will have to get back to you.
In the mean time, cyl 1 and cyl 4 are the front of each bank, 1 being the passenger side.
Old Apr 8, 2007 | 08:28 AM
Mel902's Avatar
Mel902
Try this site ,it tell you the fireing order http://www.autozone.com/az/cds/en_us...rInfoPages.htm
