how do you test a 3g alternator? it is new,just replaced. when moving on road voltage ok. when stopped with defrost etc. on drops down , dims headlites etc. new battery, batt. voltage ok, when idoling in driveway charging ok. this has done this since i purchased vehicle. I'm about to pull my hair out, can someone help?thanks.
take it to your local part store and have them test the alt under a load with their
tester, most places will check it for free, infact never heard of anyone charging
to test.
It does'nt have to be a part store, most auto places should be able to perform the test.
Check the size of the pulleys as compared tostock size.I swapped a 4 inch underdrive crank pulley on my truck and my headlights dim too....of course I didn't do the whole kit....your stock crankpulley is a 6 inch.....
THANKS THATS A GOOD ONE THAT I HADN'T THOUGHT OF I WILL CHECK TOMORROW.
i haven't been able to find specs. on what size pulleys are supposed to be on my 302. Anybody know where to look?I think my crank is 5".
i found a 95 5.0 and got the measurements today, it looks as if they replaced my crank pulley with a 5". The 95 crank pulley is about 7". Ordered one today, this should make a big difference, thanks. I will keep you posted.
