AC help
Old Apr 30, 2007 | 02:33 PM
c_hohensee's Avatar
c_hohensee
The actuator motor is on the bottom side of the heater box under the dash in the center. If you have a console you will need to get it out of the way to get to it. It is a squarish white box about 3 inches square and about 1 inch thick. The shaft runs vertically. If it is the blend door it could be worse, I just did one on a Windstar for a neighbor and not only did the dash have to come out you had to replace the whole box including the AC condenser coil. The price on that at the stealer was $450.
Old May 1, 2007 | 08:26 AM
kennedyford's Avatar
kennedyford
Thanks Craig. Ive eleminated the blend door as the culprit already. It seems I may be looking at a compressor or a plugged orfice. It seems the high side is only reaching 150 and the low stays at 30. The line to the rear condensor is cold which is acting like the 134 is changing to gas during the travel to the rear. Not enouph 134, the compressor is not keeping up or finally a orfice tube is plugging up.
ihandy
Sep 14, 2013 06:37 PM
okaw
Oct 12, 2006 11:11 AM
bligh61
Sep 9, 2004 07:50 PM
Redone
Jul 23, 2004 01:58 PM
emboyd
1978 - 1996 Big Bronco
Apr 6, 2002 07:30 AM
