1966 Sun Visor Arm
Old Apr 5, 2007 | 10:13 PM
codymoch's Avatar
codymoch
1966 Sun Visor Arm
I purchased new sun visor arm(s) and sun visors for a 1966 F100. The issue I am having is the sun visor arm only goes to the middle of the sun visor pad so it sags. It also won't stay up. What am I doing wrong?
Thanks
Old Apr 6, 2007 | 12:37 AM
ras4434's Avatar
ras4434
Smile
CODYMOCH: The pad should slide on far enough to leave an inch or so of the arm exposed so it can rest in the clip that is attached above the windshield and windshield rubber. That is if you got the right parts. Measure twice and push real hard once Good luck
Old Apr 6, 2007 | 12:52 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The sun visor clip fits all 1961-66 F series trucks, and all the Econolines from 1961 thru 1967.
C1UZ-8904132-A .. Sun Visor Clip
52369-S13 .. Sun Visor Clip Screw .. Oval Head-Cross Recess~No. 10-12 x 7/8"
Old Apr 6, 2007 | 06:43 AM
codymoch's Avatar
codymoch
This is what I am missing. I do see the screw holes in the cab close to the rear view mirrow (not sure if this is where the clip mounts or not). I will look up the part.
Thanks!
Old Apr 7, 2007 | 05:02 AM
NumberDummy
Originally Posted by codymoch
This is what I am missing. I do see the screw holes in the cab close to the rear view mirrow (not sure if this is where the clip mounts or not). I will look up the part.Thanks!
That's where the clip mounts, one screw hole per side. The clips are plastic and snap off, that's why they're missing.
juang316
WTB - Parts & other
Nov 14, 2013 10:28 AM
lilrobo
Aug 13, 2013 03:56 PM
stadtspolizei
1947 and Older Ford Trucks
Jun 5, 2010 08:53 PM
kdmcinnes
Jan 21, 2006 01:19 PM
kodakker
Aug 16, 2004 02:14 PM
