Michigan Chapter Join Chapter, Leader: Toyman
Vacume Can problems
Old 08-09-2007, 02:30 PM
Talyn's Avatar
Talyn
Talyn is offline
Vacume Can problems
Mine doesn't actually hold a vacume. I have vacume going to the can, but none comming out.
I forgot what it does.
Should i fix it?
Old 08-10-2007, 05:46 AM
Crash687's Avatar
Crash687
Crash687 is offline
Your vacuum can stores "a vacuum" so that your climate controls still work under acceleration. you can pressurize it with no more than 15 psi to check for leaks. I fit leaks replace it.
Old 08-10-2007, 08:33 AM
Talyn's Avatar
Talyn
Talyn is offline
Yea, my Vents change during accelleration sometimes.
Better change it then.
Thanks crash!
Old 08-11-2007, 03:31 AM
Crash687's Avatar
Crash687
Crash687 is offline
check it first, it could be a bad vacuum hose or solenoid valve. hoses on older cars tend to dry out and crack.
Old 08-11-2007, 09:45 AM
Talyn's Avatar
Talyn
Talyn is offline
I checked the vacuum a while back. And got nothing out of the can.
But the in line for the vacuum read good.
I thought I was having a vacuum problem causing my poor gas mileage.
It's a bad FPR.
Taylormade1
1997 - 2003 F150
11-06-2012 09:46 AM
kipdog
Modular V10 (6.8l)
01-25-2011 05:36 PM
leedeleon
1997 - 2003 F150
06-09-2005 01:23 PM
akmud
43
03-05-2004 01:34 PM
Quick Reply: Vacume Can problems
