Vacume Can problems
Mine doesn't actually hold a vacume. I have vacume going to the can, but none comming out.
I forgot what it does. Should i fix it? |
Your vacuum can stores "a vacuum" so that your climate controls still work under acceleration. you can pressurize it with no more than 15 psi to check for leaks. I fit leaks replace it.
Yea, my Vents change during accelleration sometimes.
Better change it then. Thanks crash! |
check it first, it could be a bad vacuum hose or solenoid valve. hoses on older cars tend to dry out and crack.
I checked the vacuum a while back. And got nothing out of the can.
But the in line for the vacuum read good. I thought I was having a vacuum problem causing my poor gas mileage. It's a bad FPR. |
