Is there anyone that can tell me what all the tow/haul mode on the torqshift does? Other than the obvious shift point changes and engine braking, is there anything else? A friend of mine pulls a backhoe almost all the time with his 06 F-350 psd and he only uses the tow/haul to slow down. The lower rpm's put him in the torque band and he realizes a lot better fuel economy. I've been told that in GM trannys the tow/haul engages more clutches. This makes me wonder if all of us towing without using the tow/haul on the fords aren't costing ourselves more than we are saving. What does everyone else think? You guys are a great help and I appreciate your opinions and knowledge.
Maybe the tech's can tell you better, but to my knowledge, the tow haul mode only does what you describe. The advantage to holding the shiftpoints higher would be 1. so that you dont lug the engine with a load on it. 2. Higher line pressure will prevent transmission slippage, which causes heat, hence transmission failure. You can be slightly slipping a trans without even knowing it and once the damage is done it's too late. Tow haul was put in there by Ford engineers for a reason and should be used when towing or hauling heavy loads. You hit the nail right on the head yourself when you said, "This makes me wonder if all of us towing without using the tow/haul on the fords aren't costing ourselves more than we are saving." A few more pennies for fuel now verses 4 grand or so for a new tranny later.
I hardly ever haul much with mine, and when I do its not a whole lot. I don't like to see a good buddy tearing up his investment though. Sounds like we are damn near twins, I have an 06 F-350 thats dark stone. I just have the XLT package and I'm sitting on 18's. I appreciate your input. That's kind of what common sense would tell a guy to do I would think, I was just wondering what everyone else thought. Thanks man.
Thanks for your opinions guys, I appreciate it. Do you guys know anything about the tow/haul on the allison? I'm wondering if the extra clutches rumor I have heard is fact, just for personal info. I don't know much about this stuff but I own it, therefore I want to know what's going on. Thanks again guys.
A co-worker of mine has an '07 D-Max and from his description, the Alison works almost exactly the same as the TorqueShift. Have no idea if internally it is doing things differently, but from an operational standpoint, they are nearly twins. The chagne to shift points, lockup, hold on deceleration, and also the auto downshift when decelerating and tap on brake - all nearly the same. Also one other fact that not many people know, the TorqueShift is a 6 speed (no typo). During its upshift, it skips 4th gear. When in real cold conditions, it will use 4th and skip 5th. So most driving you will only see 5 gears. During a hard pull, you will actually see all of them. Start pulling a good hill to where it will downshift out of overdrive (6 to 5th gear). If you pull hard enough of step on the throttle enough to down shift again, you will notice only about 300 RPM gain. That is the true 4th gear.
What little we have pulled with our 2 Fords, me and dad have both thought there was an extra gear in there somewhere. I have heard a few different explanations but I never heard that they were actually 6 speeds, until I got on here. Thanks for the info.
No problem. As an FYI below are the transmission gear ratios. When you look at how close 4th and 5th are you can understand the logic of skipping on, especially considering the power these engines have.
1st - 3.09
2nd - 2.20
3rd - 1.54
4th - 1.09
5th - 1.00
6th - 0.71
Haha, no kidding. That explains the 300 rpm difference as well. No kidding on the power as well, after using these on the farm and can't think about going back to the "good ole days" and have an older diesel or a gasser. We had a V10 once, excellent power for a gas i must say, but it would almost collapse the sides of the gas tank. Thanks for the numbers, i appreciate it.
1st - 3.09
2nd - 2.20
3rd - 1.54
4th - 1.09
5th - 1.00
6th - 0.71
That is very interesting!! What is the point of having the extra clutches to get a difference of 1.09? Seems a bit fishy/stupid to me. If ford had an clue and got a double overdrive like allison maybe people would be proud to say "I have a powerstroke AND torqueshift". I haven't taken apart a torqueshift so is there any chance of getting a double over drive? Ofcource I dont know what good it would do since the 6.4L has its max torque at 2000rpm instead of 1600!!! like the duramax. Thanks
I would agree that the double overdrive would be nice while not towing, however I have to question its usefulness with a good load on?? Since the PSD will cruise nice at 2000RPM at 70MPH (3.73 rear end), a higher gear would drop the MPH and thus MPG also, but would probably not be much use when towing. Unless that is you were then able to go with the 4.10 instead of 3.73 and maybe have the best of both worlds. All a little subjective at this point since I have not driven a Duramax (and don't really plan on it, I love this PSD). Below are listed the trans gear ratios for both trucks. You will see that the Allison is generally a little higher geared all the way through. One additional thought, on a PSD we can always add on an OD unit (like Gear Vendors, I have also listed their final ratio below) and it would split all the gears. It is not even offered for the DMax.
Boy, those sure didn't line up very good. Lets try that again...
Gear---PSD---DMax
1------3.09---3.10
2------2.20---1.81
3------1.54---1.41
4------1.09---1.00
5------1.00---0.71
6------0.71---0.61
GV-OD-0.55
All excellent points Thanks! yes if the torqueshift had a double overdrive I would get one with 4.1 instead of 3.73 RAR and yes have the best of both worlds! If I was a torqueshift engineer I would be all over the powerstroke engineers to get the max torque down to 16 or1800rpm so a double over drive would be useful. Yes I have seriously thought about a gear vendors overdrive. However, why should I pay 40k+ for a truck and then have to add a $4K overdrive gearset. That is pure nutts IMO! Plus, I know for a dodge(not sure on chevy or ford) that you can only use the gear vendors overdrive in 2 wheel drive(because it mounts AFTER the transfer case. Which is a huge deal to me because if I paid 4K for something I better be able to use it all the time everytime and whenever i dam well please! Thanks
I just traded in my 01 durramax/allison on my 07 PSD. both trucks Crewcab/4x4/shortbox/same tool boxes ect.
The chevy had an edge chip set at level3. the ford is stock.The chevy had an add on brake controller,the ford has the factory intergrated unit. My forklift weighs in at around 11,000 lbs the trailer is almost 3,000 lbs the equipment I hauled to Ga yesterday was 1000lbs on trailer,400 in truckbed. The ford pulled,stopped,and rode better than the chevy with out a doubt. I dont check fuel mileage so I have no idea wich one did better, but the safer feeling in the ford was worth a gallon or 2 of diesel.
I had it in tow/haul the whole time with both trucks. The allison used to downshift HARD when in tow mode the ford was much smoother.
Ok but you are comparing a truck with 6 yrs more technology to a truck that was an all new platform in either 2000 or 2001. I would surely hope the 07 ford would kick the living crap out of an 01 chevy. Compare your 07 ford to and 07 chevy then we will see! Thanks
