Another fuel pump problem, need help
Old Apr 7, 2007 | 02:26 PM
subford's Avatar
subford
Originally Posted by Larry Murray
Thanks for the information.
One last question regarding the relays. As I understand it the green one is for the fuel pump, the brown one for the EEC. How about the gray one. What does it control?
Larry M.
Are you sure that is a relay?
The only reference I have is for an 89 that shows the relays. It says the device closest to the fender is the Anti-Skid Brake Test Connector (an 87 may not have this) next is the EEC Relay then the Fuel Pump and the last device is the self test connectors. The self-test connector is the plug that you use to run the self-test.
Old Apr 7, 2007 | 03:31 PM
Larry Murray's Avatar
Larry Murray
Yes. It is identical in appearance to the green and brown, except it has 5 wires into the connector.
I'll see if I can get it out of Ford on Monday.
Thanks again for all the help.
Larry M.
Luinil
Nov 3, 2016 06:23 PM
TBird Larry
Jul 26, 2014 03:25 PM
23larry24
Jan 9, 2012 05:47 PM
larry2002f250
Nov 12, 2007 09:00 AM
Determan
Jun 23, 2001 07:02 AM
