Computer Chips & Tuners
Chips/Tuners/Problems
Old Apr 5, 2007 | 05:12 AM
josh04hdf250's Avatar
josh04hdf250
Ok guys, I just read several posts about tuners and programmers, including a heated exchange of knowledge between opinions. My question is not which tuner to buy or "IF" the warranty will cover damages resulting from power increasing mods, but the likelihood of such problems arising. If the dealer chooses to deny warranty to a specific occurance, they probably can (after all FORD's lawyers have more experience than mine). But, if I want to put an exhaust, mild programer and other subtle modifications on my truck, what is the real world probability that I will ever run into a warranty questionable problem? I have a 2004 F-250 4wd PSD 6.0 and understand that the torqushift tranny is likely to fail before 100k mi. what other situations should I look to find myself in? All I really want is to make my truck my own for individuality sake and not worry about legal battles or be out thousands on repair.
thank you,
josh
Old Apr 5, 2007 | 12:05 PM
sysman_rick's Avatar
sysman_rick
Post
You can't protect people from themselves. I have the Edge Evolution on my 05 5.4l 3v F-150. I'm not going to run level 3 or do any off the wall custom tunes. I use the guage function and level 2 tuning. I do not have a 5500 lb race car,it's a truck. Some users seem to feel that any modification is ok,Ford will fix it if I break it. Common sense be damned.
Just my $.02
Old Apr 5, 2007 | 05:53 PM
Johnny Langton's Avatar
Johnny Langton
thank you,
josh
If you want the warranty to be valid,then you won't change ANY of the parameters that are in the PCM. Ford only has an obligation to warranty the vehicle as it was delivered without any modifications to the calibration on the PCM. If you change anything that controls the engine management-your warranty is void, plain and simple. Since this same PCM controls the transmission,the warranty on the trans is void as well,and you're on your own for repairs. Like it or not,this is the truth,and is what you'll be arguing against if/when you have any problems.
JL
Old Apr 23, 2007 | 04:24 AM
APG's Avatar
APG
I see arguments for and against these special tuners however, My local Ford Dealer in Minnesota sells and installs Bullydog and Edge tuners. Considering that, who's problem does it become then?
Old Apr 23, 2007 | 05:52 AM
Johnny Langton
If you have a failure or problem-it's yours and yours alone. If that dealer warranties ANY powertrain repairs after installation of the aftermarket tuning device-they're defrauding Ford.
JL
Old Apr 25, 2007 | 10:21 AM
ReAX's Avatar
ReAX
That's a common practice. I know of dealerships who do the same with lifts and other performance and appearance mods. It all comes back to the paper work, one dealer installed toys, the dealer will assume the warranty. Odds are good you will not get you problems covered if you go to another dealership, but the one who installed it may have an obligation to fix anything covered in the warranty they assume/create.
I have been selling performance parts for the last 10 years, canned tunes create few problems that were not there to begin with. So rather than looking at it as a problem waiting to happen, look at it as a sign to upgrade. If the trans takes a dump at 75k, your most likely out of warranty any way and should get one capable of handling the power you are/want to produce.
Old Apr 25, 2007 | 12:03 PM
dkf's Avatar
dkf
thank you,
josh
Don't go with a crazy high HP tune. A tune for towing should be good as well as firming up the shifts.
It would be best to get a Handheld tuner and reflash the computer back to stock when taking it to the dealer. By having a handheld tuner you won't have any *****, buttons or displays on the dash to arouse suspition that the computer has been modified. Also don't plaster stickers on the truck advertising what tuner and mods you have.
Old Apr 25, 2007 | 01:25 PM
Johnny Langton
The key word here.
MODIFIED
No manufacturer has an obligation to repair a single thing on a vehicle that has been MODIFIED.
JL
Old May 14, 2007 | 10:09 PM
Camperdaddy's Avatar
Camperdaddy
I think that legally the Manufacturer still needs to prove that the modification was the sole/major cause of the failure. But by that point, your in the ring with all of those well paid lawyers.
Old May 28, 2007 | 02:29 PM
treading's Avatar
treading
Smile Question on These chips
Do they make one that will work on a 1993 EFI 5.8L? I've been looking and haven't found any.
Old May 28, 2007 | 04:16 PM
Johnny Langton
Yes,you can put a chip on a '93 EEC.
JL
Old May 29, 2007 | 04:54 AM
treading's Avatar
treading
Smile
I did find a Venom 400 on Summitracing.com but am not familiar with it. And got very confused going to http://www.autodirectsave.com/product/list/1993/Ford/F150/Performance_Parts/Performance_Chips
as there were several products that all claim to help with HP.
Has anyone out there used any of these products? I'm not looking to built a rocket sled. I have 170K on this engine and it just seems tired. I've replaced the plugs and wires, new distrib, K&N filter but was looking for a little more pep out of it while I save for a new (remanufactured) engine.
