General Diesel Discussion
Broken Glow Plug, Help
Old Apr 5, 2007 | 03:02 AM
redrocket076's Avatar
redrocket076
When I was removing the glow plugs on the drivers side of my 97 F250, the plug at the rear of the engine broke. The exterior shaft broke off and now the plug rod is stuck in place. I have tried numerous things to pull it out with no luck. Any ideas?
Old Apr 5, 2007 | 03:13 AM
Randy Pederson's Avatar
Randy Pederson
It's kinda late so the experts may not be on right now.You could try searching this problem as I seem to remember someone else having it recently sorry I can't be more help.
Old Apr 5, 2007 | 03:14 AM
Randy Pederson
PS, the search is 7th button from the left at top.
Old Apr 5, 2007 | 10:40 AM
heavymetal1's Avatar
heavymetal1
FTE Sponsor
unfortunately you will have to pull the head and tap it from the back, I did have luck 1 time using vise grips and a slide hammer attached to it but only once.
Old Apr 5, 2007 | 10:47 AM
wlihntr's Avatar
wlihntr
soak it with some PB, liquid wrech, break free ect. over night then put some towels over the plug and crank the engine...hopfully it will shoot out. stuff some rags on the head so it cant fall into the motor
