hydraulic clutch
Old Apr 4, 2007 | 09:56 PM
ashlandcat's Avatar
ashlandcat
Thumbs up hydraulic clutch
have a 51f1...definately on the dark side.....sbc/4 spd...trying to hook up a hydraulic clutch....anyone tried this and did it work....and how?...can't seem to get it to open up....bout ready to put the automatick back in...tks,ashlandcat
Old Apr 4, 2007 | 10:11 PM
Fomoko1's Avatar
Fomoko1
It should work, what seems to be the problem?
Old Apr 5, 2007 | 05:51 PM
rhopper's Avatar
rhopper
Ashie, (boy, smile when you say that...), what type of hyd setup are you wanting to run? The easy way is to use a hyd throwout bearing, and just fab a bracket for a clutch master cylinder.The parts, minus the bracket, are available in all the hot rod catalogs. I've heard a few bad reports about the reliablity of the hyd throwout bearings, however. I'm using a camaro clutch slave cylinder, and I'm going to try a cherokee master cylinder, which is just a girling mc with the resevoir attached, unlike the camaro mc, which has a remote resevoir. Alittle bracket fabbing and it should be good to go.
Old Apr 6, 2007 | 03:55 PM
CaptCrunch's Avatar
CaptCrunch
I run a hyd setup in my 54. I used a junkyard 59 f100 pedal setup, an old 65 ford single master cylinder I removed the redisual valve from, and an aftermarket external slave cylinder. It runs a T5 so the operation is opposite of a GM 4spd, but that is just a change in slave cylinder selection. I think the externals are alot easier to deal with in a custom setup... at least you don't have to pull the tranny to shim or de-shim.
CdnWillyG
16
Aug 24, 2013 11:58 PM
corndoggydog
1983 - 2012 Ranger & B-Series
Mar 28, 2004 01:10 PM
meierk
Jul 31, 2001 07:36 PM
perrymb
Mar 11, 2001 08:43 AM
otto
Mar 1, 2001 06:58 AM
