totally confused
Old Apr 4, 2007 | 09:54 PM
orecitycraver's Avatar
orecitycraver
Unhappy totally confused
I have a 1992 Ford Ranger 2wd 4.0 6 cylinder that will turn over but is not firing. We have changed the coil pack and the crank sensor. Can anyone suggest anything else??
Old Apr 4, 2007 | 10:55 PM
RangerPilot's Avatar
RangerPilot
Does the tach work when the engine is cranked over? I assume you have grounded one of the spark plugs out of a cylinder to confirm it's actually not firing. Fuel pump runs good?
Anything major recently done to the engine?
Old Apr 5, 2007 | 07:08 AM
orecitycraver
what is the tach??? yes the spark plug thing was done. the fuel pump is fine. It is just not firing. The only thing that has been done is what I have listed.
Old Apr 5, 2007 | 08:18 AM
Rockledge's Avatar
Rockledge
Pull the codes. You can do it yourself. Find the EEC Test Connectors under the hood and go at it.
http://www.shophoenixproject.com/eec/eec.htm
Old Apr 5, 2007 | 08:23 AM
orecitycraver
how do you test them and is this for a 1992 Ford Ranger also???
Old Apr 5, 2007 | 08:42 AM
Rockledge's Avatar
Rockledge
Yes, it's for all Fords older than 1995. You have to find the EEC Test Connectors under the hood and then use a jumper wire (even a paper clip works) to connect the two as shown in the link. Then you sit in your car and watch the CEL flash and you count the flashes.
