A friend of mine is looking into buying an 04 F250 6.0L PSD. I offered some friendly help with an oasis report. His V.I.N. # 1FTNW21P14EC73081.Any help would be appreciated. Much thanks.
Go find "gone4x4" and shoot him the info. He's been great at pulling an OASIS report for folks.
I'll only cost you a couple of rolling rocks!
Well, hopefully he's roaming the forums and stumbles across this post. If you see him, mention this, if you would be so kind.Thanks msgtg.....btw...well worth a couple rolling rocks!
Superstition Ford at 14567 miles performed 05-c-29 (cac tube replacement) 05-s-34 (ficm harness repair) and reprogram as per tsb 03-20-12 (black smoke) replaced degas bottle cap. Berge Ford at 27533 miles performed 05-e-15 (replaced ep sensor and recalibrated) Thats all thats listed.
This is just a friendly reminder (or in some cases it may be a lesson) about Reputation or Rep points. Notice that at the top of each thread…over to the right you see a green box or in some cases multiple green boxes. The more boxes, the higher the poster’s reputation on the FTE. Do a mouseover the green boxs) and it’ll give you that person’s rating.
When you feel that somebody has given good advice or has helped you with a question or issue there is a way to say “Thank You” to them. On the other side of the coin, if you feel somebody has provided bad information or that a post should be removed, you can also use this tool. They are called Rep Points.
Note at the top of the thread, there is a little scale symbol. Click this and you get a window that opens. There are two check blocks available, I approve or I disapprove. Check the appropriate block and make sure you enter a comment.
When you feel this is appropriate, use the system to give feedback to the folks who take the time to share information with us!
Thanks Valoney, much appreciated reply. I will pass the info along to a friend, it sounds like a safe bet, although the degas cap issue alway raises some concern with the headgaskets/egr cooler.
Msgtg, I was was unaware of the feedback feature on this forum, so, thanks also to you for that info.The post was very much appreciated and highly approved!
