Problem: Dash lights are really dim
Old Apr 7, 2007 | 04:47 PM
82F1507.5's Avatar
82F1507.5
This is a very common complaint regarding the 1980-1986 F-Series trucks.
The key problem is just as Mil1ion pointed out. Corrosion.
A grade school childs pencil eraser will work just fine on the exposed traces of the printed circuit film. You don't need to remove the film from the cluster, just the lamps. Good time to replace the burned out ones as well.
The next most common is the voltage regualtor connection (this regulator is mounted on the back of the cluster and should be called a ballast and looks like a tiny harmonica). Clean the contacts and regulator with KROIL.
Next most common is the headlamp switch. Disconnect the battery. Pull the switch to full ON and look behind the **** for an indent by twirling the **** in your fingers while looking. Press the indent with a pick or like device while pulling on the ****, it will slide right off. Remove the switch from the dash. You don't need to unplug it if you don't want to but do lower it from the dash to spray the internals with KROIL while working the switch in/out/twist/turn. Replace switch and ****. Reconnect the battery. Done!
Old Apr 7, 2007 | 07:34 PM
Mil1ion's Avatar
Mil1ion
Quote:The next most common is the voltage regualtor connection (this regulator is mounted on the back of the cluster and should be called a ballast and looks like a tiny harmonica). Clean the contacts and regulator with KROIL.
actually one term is : Instrument Cluster Voltage regulator
http://info.rockauto.com/SMP/SMPDeta...ml?VRC606.html
and is shown here marked by Red Text attached to the cluster back
They are grounded and provide a 5 volt pulsing signal to the Fuel,Oil,Temp sending units.
Most problems with gauges can be traced to this spot.
The ICVR has nothing to do with the Cluster Bulbs (Cluster lighting)
Old Apr 8, 2007 | 06:08 AM
82F1507.5's Avatar
82F1507.5
Agreed........IVCR has nothing to do with cluster bulbs but still is a ballast and should be free from corrosion when servicing the cluster.
The pictured cluster does not appear to be from an 80-86 F-Series truck, or should I say it does not look like any of the ones I've used.
Old Apr 8, 2007 | 03:53 PM
Mil1ion's Avatar
Mil1ion
It isn't but the principle is the same.
I'm a little short on 80's F-series clusters.
BTW, No need for quote espeically with image.....all it does is make the page longer
a simple address to me
ie: Dennis
blah blah blah ......
works fine.
Old Apr 8, 2007 | 06:08 PM
kermmydog's Avatar
kermmydog
I'm glad someone finally asked about this problem now I know how to fix mine.
Old May 10, 2007 | 07:31 AM
CaptGuz's Avatar
CaptGuz
I've been having the same problem with my lights - i'll be checking this out in the next week or so I hope.
asmith6
Mar 5, 2016 05:34 AM
Jayrod00
2004 - 2008 F150
Jan 4, 2016 08:36 PM
ReBilld
Mar 26, 2012 04:34 PM
Windmill
Dec 2, 2011 01:21 PM
Ted Bell
Oct 6, 2011 01:25 PM
