power loss
Old Apr 4, 2007 | 11:44 AM
dogman1313's Avatar
dogman1313
power loss
I have a 2002 f-250 that looses power when we use biodiesel. The 2000 f-250 we have run fine on 100% biodiesel. Is there any difference in these 2 engines that would cause this?
Thanks
Dave
Old Apr 4, 2007 | 12:44 PM
Pocket's Avatar
Pocket
No difference, they should both run it the same.
Unless there is some blockage on the '02. How long ago did you change the fuel filter?
Old Apr 4, 2007 | 04:39 PM
dogman1313's Avatar
dogman1313
We changed the filter when we added the biodiesel, the biodiesel was filtered to 10 microns. It ran fine until the next day.
Old May 16, 2007 | 11:47 PM
jimmye4golf's Avatar
jimmye4golf
Trailering
Is there more than one fuel filter on an F250? I thought I read once that there is one under the hood and one under the cab on the frame rail. Not sure.
Old May 17, 2007 | 06:41 AM
white Buffalo's Avatar
white Buffalo
Try changing the fuel filter again. When first using biodiesel, especially the higher levels, it can act as a fuel system cleaner and flush out all the builup in the sytem and clog up the filter. Just the one fuel filter under the hood.
