Delaware Chapter Join Chapter, Leader:
April chat thread
Old Apr 14, 2007 | 09:45 PM
  #106
glruff's Avatar
glruff
FTE Leadership Emeritus
21st of April before the meet-n-greet.
That is if danlee has our '53 all modded up.
Old Apr 14, 2007 | 09:49 PM
  #107
glruff's Avatar
glruff
Originally Posted by Garrity
When are they racing at Cecil? I read the whole thing and must have missed the race date.
See posts 34, 35, & 36
  #108
Mark _G's Avatar
Mark _G
Oh well. Gotta work.
Old Apr 14, 2007 | 09:55 PM
  #109
danlee's Avatar
danlee
Originally Posted by phil6608
Yes it's an auto. I'm running a 2600 stall. On 28" M/T street ETs- 4.10 gears.
I'm running an 1800 stall on worn BFG T/A radials and 3.25 gears. The tires are about 28" diameter, but they wouldn't do very good on the track. i am thinking about a set of Hoosiers.
My motor has a flat torque curve, but I pick up about 70 ft-lbs torque between 1800 and 2500 RPM, that helps a bunch. It doesn't rev high enough to use gear ratios higher than about 3.89:1. The motor is built to rev higher, but it just can't get enough air to feed 434 cubes above 5500 RPM.
Old Apr 14, 2007 | 10:04 PM
  #110
phil6608's Avatar
phil6608
I just got a set of 30" wheels and M&H street drag tires to try and get my RPMs down a little.With the 28s I'm turning around 6000 RPMs at the end of the 1/4
Old Apr 15, 2007 | 06:08 AM
  #111
danlee's Avatar
danlee
Phil,
Did you ever run any simulations on your setup? Since you have some history at the track, a sim should help you foccus in potentil improvements.
Old Apr 15, 2007 | 08:10 AM
  #112
phil6608's Avatar
phil6608
Originally Posted by danlee
Phil,
Simulations,,,,whats that????
The track is my testing ground.
Old Apr 15, 2007 | 11:25 AM
  #113
danlee's Avatar
danlee
I have both engine and drag simulation software. I know it doesn't take the place of a real track, but you can change combinations a lot more easily, and you can do it in any weather.
Old Apr 15, 2007 | 01:13 PM
  #114
glruff's Avatar
glruff
Dan what Phil meant to say was:
1. What info do you need to run a sim for me?
2. I need all the help I can get to beat your '53.
Old Apr 18, 2007 | 07:20 AM
  #115
savage2211's Avatar
savage2211
Well Guys This is my 500th post. I will catch george yet...
he he he
Old Apr 18, 2007 | 07:24 AM
  #116
glruff's Avatar
glruff
Everybody who reaches 500 posts has to become a SUPPORTER. lol
Old Apr 18, 2007 | 07:27 AM
  #117
savage2211's Avatar
savage2211
I am thinking about it. LOL but thanks to you George I already have the t shirt.....
By the way, I hear that there are things and threads that you can only see and use if you are a supporter. Is that right George
Old Apr 18, 2007 | 07:29 AM
  #118
glruff's Avatar
glruff
That is correct. There is a Club FTE forum just for supporters.
Inaddition, the ads go away, and alot more benefits.
Check it out here: http://www.clubfte.com/
When you get your shirt you can give it to me since you got mine. lol
Old Apr 18, 2007 | 07:31 AM
  #119
savage2211's Avatar
savage2211
Hey George, Hows Your first day of vacation?
Old Apr 18, 2007 | 07:34 AM
  #120
glruff's Avatar
glruff
Kinda like jet lag. You go so hard for so long and then come to a screeching halt.
Mentally drained but physically ok. Will be better after a couple of afternoon naps. hehehe
Wow, this was post #3,200 for the Delaware Chapter. Yahoo!
