Sponsored by: Real Truck
Egt!!!
Old Apr 3, 2007 | 09:54 PM
OLD 97's Avatar
OLD 97
Egt!!!
Can anyone tell me what a safe egt is??
Old Apr 3, 2007 | 10:07 PM
CSIPSD's Avatar
CSIPSD
For what? A PSD... with a pre turbo pyro, 1250 is the standard red line... I run all day at 1250 and never an issue.
Old Apr 3, 2007 | 10:12 PM
OLD 97's Avatar
OLD 97
Well, I have a 07 F 250 6.0 with the Edge Juice Platinum Programmer and i have the alert set at at 1250 and sometimes with normal driving it goes crazy beeping and saying that the egt is like 1400! I was just curious cuz I dont wanna blow some **** up. lol
Old Apr 3, 2007 | 10:16 PM
CSIPSD's Avatar
CSIPSD
Short times above 1250 will not hurt anything. 10-20 seconds is fine.
Old Apr 3, 2007 | 10:21 PM
OLD 97's Avatar
OLD 97
Sometimes it alerts me that they are too high, and i have the programmer set on stock. What about before i even put the programmer on? Was it a problem ya think? hmmm......I dont know alot about "egt" so i guess you think the question is kinda strange.
Old Apr 3, 2007 | 10:26 PM
CSIPSD's Avatar
CSIPSD
I would bet you have a flaky unit. You should never see more then 1100 on stock. Might talk to Edge.
Old Apr 3, 2007 | 10:36 PM
6L PWR's Avatar
6L PWR
I know my '06 has seen above 2000. Bigger injectors will do that. Way not reccomended though.
Old Apr 3, 2007 | 10:38 PM
6L PWR's Avatar
6L PWR
When I had the Edge and stock injectors, I never saw over 1150 when in stock setting. However, when on level 5 or 6, I'd see 1550-1600 at the track.
Old Apr 3, 2007 | 11:59 PM
OLD 97's Avatar
OLD 97
Thanks for the answers and advice
Old Jul 10, 2007 | 10:30 PM
cerroneseuropean's Avatar
cerroneseuropean
Cool High EGT & engine temp overheat
Hi Guys I have a 06 SD 6.0power stroke,I have a edge platinum programmer with juice. it has been great till recently.I have had a problem with egt spiking to 700
to 1250 (no change in load what so ever) at cruising stopped vehicle & checkd water leval topped of & then parke truck till sunday drive home.before starting I disconnected edge programer went back to stock setup & drove vehicle back with not one single problem!1 & it was 100 degree weathe I ran the heck out of it on the hills & still ok!! I got home & checked coolant level & didnt lose a drop!!has anyone herd of this before ? I contacted Edge & they said they would send me a complet new unit!! I am a little concerned about having somthing onj my truck that will cause this again!!any words of wisdom would be appricieted thank you Frank
