Sponsored by: Auxito
Auto rear window in Screw
Old Aug 1, 2002 | 12:21 AM
argann's Avatar
argann
Wanted to find out if anyone out there has done the auto sliding rear window on there screw. Any idea what the dealer slaps you for to put one of these in. I found them for I guess compared to ford a good price. Just want to see what the install is going to be like.
Old Aug 7, 2002 | 08:00 AM
copeina's Avatar
copeina
I watched a guy put one of those in his 1997 F150. It went in like a dream once the interior panels came off. Pulling those clips was the hardest part of the job.
Follow the directions that should come with the kit and you should have no problems. Confidence is 99% of the task!
Good luck,
/Kris
Old Aug 8, 2002 | 03:28 PM
pilot10's Avatar
pilot10
I've been wanting to put one in my truck as well. I just called a local shop(Campways, Mtn View, CA) and they want $359.99 + $125 to install it.
It's been about twenty years since I put a rear slider in so I'm thinking $125 isn't that bad. But on the other hand the tool to pop off those interior panel clips is probably a lot less and then you'd have the satisfaction of doing it yourself and a little extra gas money.
Tim
Old Aug 9, 2002 | 10:43 PM
copeina's Avatar
copeina
... and if your shop rates are the standard $75 an hour they are here, it is only a 2 hour job!
Good luck - Go for it!
/Kris
Old Aug 15, 2002 | 12:39 AM
argann's Avatar
argann
Any one know where they put the switch for it? I am guess power came from the fust box but I could be wrong.....
Old Sep 30, 2002 | 06:33 PM
Goober's Avatar
Goober
I saw someone selling this slider window on Ebay but it does not have the switch. It was going for $195.
Old Nov 9, 2002 | 03:05 PM
Eds Shadow's Avatar
Eds Shadow
they put the switch where ever you want it
Old Nov 9, 2002 | 03:17 PM
blacklightningf150's Avatar
blacklightningf150
