Check Engine Light and Sensors?
Old Apr 4, 2007 | 10:16 AM
pawpaw's Avatar
pawpaw
Wonder if it may be as simple as the wrong heat range spark plug????
Seems to me I remember Bob Ayers fixed the ping on his 3.0L, with a change in plug heat range, but I can't rememper the plug # he went too. I suppose a search of his posts on the subject of ping, or 30L plugs, might turn it up though.
So which plugs are in the engine now????
Old Apr 4, 2007 | 10:51 AM
aquanaut20's Avatar
aquanaut20
A shot in the dark.
Have you considered that the head might be carboned, raising the compression ratio and hence instigating the ping.
Old Apr 4, 2007 | 11:16 AM
fflintstone's Avatar
fflintstone
Originally Posted by aquanaut20
A shot in the dark.
More Seafoam? Cadriver, aquanaut might have apoint. Did you change plugs with the tune up? and with what plugs. Another thing to consider is where you get gas. Do you always get it from the same place?
You might bring it in on that PCM warranty issue. Like some of the guys said earlier, you may have had the right coil all along from the factory instead of it being changed out for this issue. At least you'd find out if in fact the PCM was changed out under warranty.
Good luck
Fred
Old Apr 4, 2007 | 01:03 PM
cadriver's Avatar
cadriver
I'm using bosch spark plugs, and before they were original motorcraft, and pinging was there too.
More seafoam??? Nonsense, with only 75k on the engine, I think the hesitation can be from some sensor not working properly, or the intake might have a leak
which I can't find, I might change the EGR valve, because is leaking vacuum through the center shaft, read my first post on this thread.
My 94, 2.3 L had the exact same problem from the first day I got it, and after years of replacing sensors, sparkplugs, nothing worked it was always pinging in hard acceleration and uphill, my biggest disappointment with these Rangers is the pinging thing, and I wasn't expecting to have pinging from a V6, 2000 model and 75k miles on it, I guess is about time for me to look for some other vehicle maker!
Old Apr 4, 2007 | 01:48 PM
aquanaut20's Avatar
aquanaut20
IMO, these ford engines do not like BOSCH plugs, have tried a few sets, which broke down in 1000k, sent them to Bosch for testing, they advised me to use different plugs.
Get good service out of NGK Platinums and Motorcraft dbl plats
Old Apr 4, 2007 | 02:48 PM
pawpaw's Avatar
pawpaw
OK, so what was the Motorcraft plug number that was giving you problems???? Was it the OEM factory plug, or had they been replaced with another heat range????
Old Apr 4, 2007 | 03:48 PM
cadriver's Avatar
cadriver
I don't remember the number, but they were Motorcraft.
I replace them with the BOSCH-PLATINUM_PLUS<!-- Quick Note --> <!-- Part Number --> 4005
If you guys believe that these are the wrong plugs, please show me proof?
I don't want to play the guessing game, replacing unessesary parts.
Thanks again........
Old Apr 4, 2007 | 04:21 PM
pawpaw's Avatar
pawpaw
Well Motorcraft lists several plugs for this engine.
I believe Bob Ayers changed his plugs from the Motorcraft AGSF22FM, to AGSF12FM to cure his 3.0L spark knock problems.
I can't speak to Bosch plugs in your engine, but enough folks on this forum have posted problems with them, that at the least they should be on your suspect short list imo.
Since you can't remember which Motorcraft plug was in this engine, were they the OEM factory plugs, delivered with the vehicle????
If so, how did they read when you removed them for replacement????
At this point I can only suggest you conider a colder plug & see how your spark knock problem goes.
Seeing as how you live in Calif. & have had spark knock problems on two of your Fords, it may also be a fuel recipe related problem too, so why not try several tanks of Chevron, CalTex, or Texaco & see what gives????
Old Apr 4, 2007 | 05:47 PM
cadriver's Avatar
cadriver
I don't know, they were Motorcraft, that's ol I know.Sorry!
I'm glad you brought that up!
The gap was huge! I think the right gap suppose to be .042? and the ones I took out were .082!!!! maybe they were originals?
Old Apr 4, 2007 | 08:45 PM
pawpaw's Avatar
pawpaw
I just pulled my 99 4.0L plugs at 50K & they too were WAY out of spec for gap. I had removed & regapped them to the tight side of spec at about 10K, so in about 40K the gap was really out of spec. No way would they have gone 100K without regapping.
So your having found your gap so out of spec, doesn't surprise me. they probably were the OEM factory plugs.
I'm more interested in knowing how the internal ceramic insulators looked on the plugs, as that could give us some clue on which way & how much to go, on a colder plug.
If they aren't thrown awat & you could lay hands on & discover what the number was on the Motorcraft plugs removed, that would be helpful too.
Old Apr 4, 2007 | 10:00 PM
cadriver's Avatar
cadriver
Brownish rusty color, normal ol 6.
Old Apr 4, 2007 | 10:16 PM
pawpaw's Avatar
pawpaw
OK, well it would seem the only thing common about all this is that you probably use the same fuel in both these vehicles.
So the only things I can suggest at this point is, try changing the fuel recipe , in the brands I suggested previously, for 5-6 tanks & see what happens.
If the 3.0L still pings & seeing as how you've tried a decarbon with Seafoam, consider trying a colder Motorcraft plug like Bob did & see what transpires.
Let us now what you find.
Old Apr 5, 2007 | 12:23 AM
  #28
cadriver's Avatar
cadriver
How can you tell between a hot and cold spark plugs, most auto parts they just don't know they ask for the make, model, year of the vehicle and whatever pops up on the computer is what you get, Ford dealer does the same thing, takes the info of the car and you get what's on the list?
What about other brands? Autolite,Champion,NGK,etc.?
Old Apr 5, 2007 | 05:36 PM
  #29
pawpaw's Avatar
pawpaw
I think most of your basic plug questions can be answered by poking around here. http://www.autolite.com/carcare/techSpecs.php
Old Apr 5, 2007 | 06:38 PM
  #30
fflintstone
kuddo's Pawpaw. I smell a technical stickie!!!! yep, just checked the technical list. Stickie. Stickie!!!!
