AC blows hot while at stop
Old Apr 2, 2007 | 05:03 PM
rj24's Avatar
rj24
I've got a brand new 2007 Lariat Supercrew with the 6.5' bed and climate control. When I'm stuck in traffic for extended periods of time the AC starts blowing warm air. The air doesn't turn cold again till I start moving at a reasonable speed. If adjust the AC colder, the fan blows harder but AC doesn't get colder. Anyone else have this issue?
Old Apr 2, 2007 | 05:12 PM
04 FX4 Lineman's Avatar
04 FX4 Lineman
The AC on my 04 isn't worth the powder to blow it to hell ford says is withing specs, but I thought they fixed it in 06-07 had heard the early mmodels just had to small a compressor??
Old Apr 2, 2007 | 05:46 PM
FTE Trigger's Avatar
FTE Trigger
Hi and Welcome to Ford-Truck Enthusiasts!
"Some" were also Underfilled with ref. Let the service guys have it (provided that you're under warranty) they should automatically throw a thermometer and a maifold gauge set on.
Iirc the spec calls the exterior/interior difference should be about 40 degrees.
Old Apr 2, 2007 | 08:11 PM
BIGFISH70's Avatar
BIGFISH70
If that does not work I bought an ele fan and put it in front of the cond. and it helped alot. It will push more air threw to keep it cooled down, You got to love R134, I want my R12 back...
Old Apr 2, 2007 | 08:24 PM
rj24's Avatar
rj24
Thanks guys... I wasn't sure if I was the only one. I've had a couple of rangers and a '97 F150 with a v6 and never had a problem. This is my first v8 and it's only a month old. I guess I've got to take it in for it's first service appointment. If that doesn't work I'll try the electric fan. Do they make one specifically for the F150? Besides the AC, the truck is amazing.
Old Apr 2, 2007 | 08:31 PM
Tom's Avatar
Tom
Bigfish, where did you find the electric fan?
I'm interested in rigging something up for the tranny cooler for when I'm towing in heavy traffic...
Also, RJ24...have you tried blowing out your radiator with a pressure washer or a hose? We had that problem in Afghanistan...dust would clog the A/C condensor, and the air conditioner wouldn't work at all. we took the truck to the wash rack, had them blow the radiator out, and it went fine...
An air conditioner is nothing but a heat pump, and relies on a condensor to radiate heat out of the cabin.
Old Apr 2, 2007 | 08:54 PM
BIGFISH70's Avatar
BIGFISH70
I just went to the local auto parts house and found a one size fits all and used some zip strips to hold it in place.
Old Apr 2, 2007 | 09:36 PM
HomerWinzlow's Avatar
HomerWinzlow
They havent changed squat since 04... same crap AC since day one. Hotline says 45 at outlet average is normal. You are on your own to make it work better. Extended stops in traffic will net hotter air...period. Slower fan speeds will help.
If an external fan helps let us all know and Ill give it a go.
Old Apr 2, 2007 | 10:13 PM
nascar6dude's Avatar
nascar6dude
Crap is right.... I've got an '06 R/C and you would think with that small a cab area the A/C would freeze you out of there. Nope, blows cool but I wouldn't say COLD. And it cycles on and off so loudly it's almost embarassing when stopped at a light.
Old Apr 3, 2007 | 03:09 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
do you guys put the air recycle on? or is the outside air vent on?
mine blows freezing cold with/without air recirc
Old Apr 3, 2007 | 06:03 AM
HomerWinzlow
No, I just dont live in Seattle. I live where summer temps would kill you.
Old Apr 3, 2007 | 06:23 AM
HomerWinzlow
Nascardude, your AC shouldnt have an annoying loud clutch but they do normally have one that can be heard. All of them are like that. If its annoying loud maybe they need to close the air gap on the clutch a little.
One thing that might help AC is a water valve to the heater. These do not have any vacuum controls anymore so no water valve. Maybe adding a manual controlled valve would help.
Old Apr 3, 2007 | 11:44 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
truck blew just as cold while in Texas during summer heat. Seattle is cold alot, but not always
Old Apr 3, 2007 | 09:16 PM
nascar6dude
Maybe mine isn't louder than anyone else's, I'm just not one to have the stereo blasting and I listen to vehicle sounds probably more than most people. If Ford would give us back the under hood insulation you probably wouldn't hear it at all. As for the temp, I'm in Florida, it don't get much hotter than here, especially when you're in bumper to bumper traffic. Even so, Ford should give us a stronger compressor.
Old May 30, 2007 | 10:18 AM
rj24's Avatar
rj24
Took my truck in for service. It ended up being the AC clutch. The AC works good now. Still not as cold as some of the vehicles i've owned but it does blow cold all the time now.
RJ
CLE-PRE
Jan 9, 2017 09:41 PM
ROBBINthaHOOD
Jun 16, 2016 07:21 AM
Sdowdle541
May 31, 2015 10:51 AM
BigRed7.3l
Jun 7, 2014 12:37 PM
Bombero
2004 - 2008 F150
52
Jul 16, 2007 07:52 AM
