6.9L Diesel Compression?
Old Apr 2, 2007 | 09:02 AM
turboman24's Avatar
turboman24
Question 6.9L Diesel Compression?
Does anyone know what the compression of a 1984 6.9L Diesel? I have read it was 22.5:1 and then another said 20.75:1. Also i was wondering if a diesel compression gauge will calculate this. One of those you place in the glow plug and test it.
Where can one get one of these diesel compression gauges and how much money is it?
Old Apr 2, 2007 | 09:12 AM
datamover's Avatar
datamover
I have seen them on Ebay for $50-150. I think someone here purchased a guage at NAPA for $135. I am going to check NAPA myself today. I need to get one.
Bob
Old Apr 2, 2007 | 09:18 AM
turboman24's Avatar
turboman24
Does the guage give you numbers or does it just have a green space and the compression is ok when it is in the green space; bad in the red space?
Old Apr 2, 2007 | 09:27 AM
datamover's Avatar
datamover
I am pretty sure it is numbers.
Here are some I looked at.
Bob
http://cgi.ebay.com/ebaymotors/Diese...spagenameZWDVW
http://cgi.ebay.com/ebaymotors/ws/eB...7669685&rd=1,1
Old Apr 2, 2007 | 10:42 AM
Oregon-Mike's Avatar
Oregon-Mike
I always figured that when I got around to buying one of these units I'd just pick up a cheapy from HF:
http://www.harborfreight.com/cpi/cta...emnumber=93644
Comments? Looks similar to the 1st ebay posting, substantially cheaper than the Rotunda...
Mike
Old Apr 2, 2007 | 12:59 PM
datamover's Avatar
datamover
I think I will go to Harbor freight this week and get that one. Good find! It doesn't have to last forever.
Bob
Old Apr 2, 2007 | 01:44 PM
turboman24's Avatar
turboman24
Thanks for the info guys
Old Jun 21, 2008 | 06:23 PM
rmalottwtes30's Avatar
rmalottwtes30
Went to Harbor Freight today and got a diesel one for 39 bucks, I did a compression check on the #2 cylinder. I dont know if I did it right or not but I cranked like 20 seconds and it read around 450psi. Is that good or bad? I really dont know the typical compression of a diesel.
Old Jun 21, 2008 | 07:04 PM
Lead Head's Avatar
Lead Head
400-500 PSI is good. But 20 seconds is much to long, and will put a strain on the your starter.
Your only supposed to crank it for 3 compression cycles, long enough so that the engine hits the compression stroke on the cylinder your testing 3 times. So you will see the needle go up 3 times. If you do more then that, you may be skewing the results.
Old Jun 21, 2008 | 08:14 PM
rmalottwtes30
I just did some research on how long to crank it. I dug out my 6.9 and 7.3 manual and it says 8 times to get the proper reading. The manual that came with the compression checker said to 6 times. You say 3 times....What should I go by?
Is between 400 and 500 typical?
Old Jun 21, 2008 | 09:50 PM
Dave Sponaugle's Avatar
Dave Sponaugle
I would go by the gauge manual, so 6 times.
Just remember to do it the exact same way for all cylinders.
400 to 500 is good.
Lowest cylinder should also be within 10% of the highest cylinder.
So if the highest is 450, 450*.10 = 45, 450 - 45 = 405, the lowest should be over 405.
6.9 should be 22.5 to 1.
7.3 should be 21.5 to 1.
Old Jun 22, 2008 | 07:29 PM
lowell75's Avatar
lowell75
2 cents worth .... the harbor freight and EBAY units are most probably going to be identical and while they are not badly made , they are very difficult to use on most of cylinders of the IDI...I could use it only 3 cylinders without pulling injector lines. The usable adapter is straight in and it needs to be angled instead... you could buy the the kit and a better adapter is available elsewhere!
ddeflyer
Mar 4, 2015 08:19 PM
ddeflyer
Feb 11, 2015 08:32 AM
justforkicks
Jan 7, 2015 02:41 PM
Ford F834
Aug 9, 2014 10:08 PM
queen of spades
15
Sep 24, 2013 11:48 AM
