Sponsored by: Real Truck
E Brake on 4 wheel Disc
Old Apr 1, 2007 | 09:08 PM
TPM's Avatar
TPM
Anyone ever have the emergency brake fail - the kind that goes around the driveshaft. What were the symptoms?
How does one replace these things -is there a brand or type to use?
Old Apr 2, 2007 | 12:14 AM
TPM's Avatar
TPM
Think I figured it out
Carrier Bearing. I have been reading posts for the past 4 hours and it seems the closest diagnosis I can find is the carrier bearing. That makes sense.
The instructions I found for repairing this will make it very easy to get it done myself tomorrow.
Old Apr 2, 2007 | 01:19 AM
Monsta's Avatar
Monsta
Sit. Stay.
What Super Duty truck do you have that has the parking brake on the driveshaft?
Old Apr 2, 2007 | 01:25 AM
TPM's Avatar
TPM
E Superduty
97 E Superduty, now known as a 450. 7.3L PSD with E40D transmission. It is a cutaway van ambulance conversion. Rear discs so the parking brake is a hub with shoes that fits between the transmission and the driveshaft.
If I could post an attachment I'd show a picture. The parking brake cable goes from the foot pedal to the hub straight away.
Old Apr 2, 2007 | 01:40 AM
Monsta's Avatar
Monsta
Sit. Stay.
Okay...I dig. I've seen them before. Wasn't even thinking about a 97 cut-away!
So what exactly is the problem you're having?
Old Apr 2, 2007 | 09:25 AM
TPM's Avatar
TPM
Horrible Grinding Sound
Horrible grinding sound from under the truck that sounded like it was the transmission. Just before I parked it it felt like it was binding or slowing the truck down.
The full story is here.
I have since drained and checked the rear end. It is all perfect. That leaves the OD, the parking brake or the carrier bearing.
Thanks for helping.
Old Apr 2, 2007 | 10:54 PM
XLnAK's Avatar
XLnAK
Gotta be the carrier bearing. They do just that. Drove one in four low to a service center once. Not recomended. I have a 83 crewcab longbed that I've driven for 17 yrs and have had to replace a few.
Old Apr 3, 2007 | 07:31 PM
TPM's Avatar
TPM
Problem Found - its the parking brake assembly
Now I if I can figure out how to get it fixed. One shop says Ford has the replacement backing plates and shoes.
Carrier bearing seemed just fine.
How do i get the ability to post images?
