locking hood
Old Apr 1, 2007 | 04:38 PM
460stick's Avatar
460stick
locking hood
Does anyone have a picture of how to run the cable for the locking hood through the engine compartment? For a 1978 f 250
Old Apr 2, 2007 | 10:58 PM
F350 Strait's Avatar
F350 Strait
Re the hood hatch
The hood release cable runs down the top of the left inner liner & thru the radiator support then over to the hood latch. I can send a picture if you haven't figured it out yet.
Old Apr 2, 2007 | 11:08 PM
Mil1ion's Avatar
Mil1ion
Here you go.
Old Apr 3, 2007 | 07:53 AM
460stick's Avatar
460stick
Thanks for the pic and info
Old Apr 3, 2007 | 01:00 PM
Mil1ion's Avatar
Mil1ion
The cable is supposed to have 3 or 4 little plastic hold down clips that get inserted into holes along the inner fender.
I'm still looking for some that aren't old and broken.
Old Apr 3, 2007 | 01:33 PM
Jermafenser's Avatar
Jermafenser
Doesn't the locking hood has a different latch that you need to swap out to work with the locking hood instead of the standard latch?
Old Apr 3, 2007 | 01:42 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Yes, and Ford offered an accessory hood lock kit with everything to install one. The latch (only part of the kit that's the same) is the same one Econolines used, and might still be available from Ford. Original part number D8TZ-16700-B replaced by >>> E7UZ-16700-A
D8TZ-16700-A .. Hood Lock Kit~Key Operated
Picture in 1973/79 Truck parts illustration: Section 160, page 9.
Old Apr 3, 2007 | 01:47 PM
Mil1ion's Avatar
Mil1ion
Yes, let's hope the OP has that part as well
Although he can still install the cable part.
Old Apr 3, 2007 | 02:52 PM
460stick's Avatar
460stick
thanks for the info. I just got it installed on my truck!
