Converting Cruise Control
Old Apr 1, 2007 | 10:04 AM
Bill77F250's Avatar
Bill77F250
HI,
I have a 77 F250 Supercab, (2wd, power steering) and came across a 77 regular cab (2wd, power steering) with factory cruise control in a junk yard. I would really like to get this and put it into my truck.
I have done some searching around trying to find out exactly I would need to take to convert over. It appears that I need column, wiring harness and what looks like a control box under the dash. Will this wiring harness plug into my existing harness? Will I need to make major electrical changes?
Does anyone have a good write up and or diagram that shows what to do with this?
Bill
Old Apr 1, 2007 | 01:52 PM
Mil1ion's Avatar
Mil1ion
Sorry, There's more parts than that needed.
I have everything you will need information wise to do the swap over with little trouble.
I have a couple of threads with a complete list of what one needs in them.
Here's one of them.
https://www.ford-trucks.com/forums/1...rol-retro.html
Unfortunately you have the hardest year for this unless you go with a 78/79 tilt column.
You see.,.... the Turn Signal switch for a 77 with cruise control is NO LONGER available anywhere.
So unless the turn signal switch for the 77 w/cruise is good..you are SOL.
Old Apr 1, 2007 | 03:01 PM
Bill77F250's Avatar
Bill77F250
Uggh,
Sounds like more than I want to deal with. Thanks for the reply :+)
If anyone is looking and wants to deal with it, the truck is at the Ecology Auto Parts in Chula Vista Ca. Baby blue 77 single cab.
Old Apr 1, 2007 | 08:00 PM
76supercab2's Avatar
76supercab2
Ya knowwwww.......
The steering wheel, horn pad, and turn signal switch are each worth about $100 to any one who needs one....
Old Apr 2, 2007 | 12:27 AM
Bill77F250's Avatar
Bill77F250
The wheel and horn pad are pretty beat, not sure on the turn signal. I will have to check it out after work tomorrow.
Old Apr 2, 2007 | 03:22 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
FYI: The steering wheel, horn pad and turn signal switch used on 1975/77 F100/350's with cruise control are the exact same parts as used on like 1975/77 Econolines. The column, however is different. Lots of these E-vans lying around in yards unmolested, as they don't have the following as the F Series trucks do.
