Fuel sender ohm setting question
When I fill my tank, my gauge reads full plus a lot - like another 1/4 tank to the right. It runs out of gas - I know this for sure! - at 3/8 tank.
So I've read a lot of the threads on this topic and got a much better understanding of how the whole system works.
I pulled the sender and ran some measurements with my ohm meter. At "full" by float position, I get about 10 ohms. At "empty", I get about 68 ohms.
If I manually position the float so my gauge reads right at full, I only need 24 ohms.
Is there a sender that fits my 76 tank that runs from about 24 to about 90-100(?) ohms? I have to guess at the resistance for empty because I can't get more than abt 70 ohms from my sender, which still only reads at 3/8 full.
I sure would like to have a gas gauge I could rely on! Thanks for any help!
With the float rod against the full stop (away from the fuel filter), the ohmmeter should read 8-12 ohms of resistance. With the float rod against the empty stop, it should read 60-68 ohms. If the resistance is not within limits, replace the sending unit.
Gauge
Bench Test
If the ohmmeter reads below 10 ohms or above 14 ohms, replace the gauge.
If the above tests are OK then you might change out the gauges 5-Volt Voltage Regulator on the back of the cluster.
I haven't checked the gauge for ohms. I went and got a new sending unit and checked its values, too. I got about 10 at full. By bending, just slightly, the stop tab for empty a bit further back, I got 80 ohms.
At 80 ohms the gauge just reads on top of the empty line. At 10, it still rises at least 1/4 past full - not such a big deal to me. I just didn't want a false reading regarding my low fuel level.
I will check the gauge, too. Does it have a resistance value deliberately built in? Since I have been consistently high on indicated level, might the gauge now have 0 resistance? A constant lack of 10-14 ohms seems just about right for my readings.
