Extra ground straps on these 70ish year Ford Trucks will help the electrical system.
Here a picture showing some added ground straps and cables from engine ground on passenger side to frame and body. Toward the right of ground strap is the negative battery cable coming from the negative battery post. https://www.ford-trucks.com/user_gal...132488&width=0
Clean all connections with a wire brush or 120+ sand paper.
I've had a lot of luck swapping out the bulbs in the instrument cluster without removing the cluster. I just stand on my head and grope around under the dash.
The bulb sockets can be taken out and put back in without messing with the dash.
I've had a lot of luck swapping out the bulbs in the instrument cluster without removing the cluster. I just stand on my head and grope around under the dash....
....OK, I'll grant you that it's possible, but I personally wanted to see what I was doing.
