Horn button ground
Old Mar 31, 2007 | 08:49 PM
MintFord's Avatar
MintFord
Horn button ground
When I bought my '77 F250, there was a toggle switch on the dash to operate the horn. I removed that cobbed up mess and discovered that the original horn circuit was intact. The problem was that the steering shaft in the middle of column was not grounded. The steering box is a good ground. The column tube is a good ground. I could not think of any other way to ground that shaft other than doing this: https://www.ford-trucks.com/user_gal...146826&width=0 It works fine for now, but I would like to know if I am missing something obvious here. Thanks.
Old Apr 1, 2007 | 01:41 PM
Mil1ion's Avatar
Mil1ion
The horn wire attaches via the steering wheel.
The column set-up
See the metal tab under the hex nuts in this pic?
That is allows a ground for the column... for the horn .....because of the rubber insulator between the metal pieces would prevent it.
So without this tab, ,,,,,,no horn worky.
Is yours there in good condition.
Old Apr 1, 2007 | 08:09 PM
76supercab2's Avatar
76supercab2
Some couplers had a wire instead of the tab. (And that would be the easy fix in the absence of the tabs) Either way, you need a path for current from the column shaft to the steering box.
Old Apr 2, 2007 | 12:24 PM
MintFord's Avatar
MintFord
Ahhhh! I can't beleive that didn't occur to me. I'm going to run a wire across there when I get home tonight. Thanks guys!
