Couple Quick Questions
Old Mar 31, 2007 | 07:24 PM
xjvince's Avatar
xjvince
I'm elbow deep in the front of my motor right now. new waterpump, vac.pump, alt. is out. got to remove the fuel filter & bracket to service t-stat and valvecover gaskets.
#1-whats the best way to break open & drain the fuel without spilling 1/2 gallon of diesel on everything??
#2-should I change the lift pump(245K+)?? its easily accessed right now. and do I need to roll the motor over to certain spot for installation??
thanks, Vince
Old Mar 31, 2007 | 10:11 PM
PLC7.3's Avatar
PLC7.3
I just remove the two bolts that hold the header in place, leave the lines attached to the filter, it will stay there. Now remove the filter bracket.....
If you want to drain it there is a little wheel and drain line under the filter..... draw off some fuel "check for water" then close the drain and unscrew the filter.
http://www.intellidog.com/dieselmann/idi.htm
Look for the filter header leak points......... pic
I would do the lift pump too.........
Old Apr 1, 2007 | 12:15 AM
xjvince's Avatar
xjvince
thanks Pete, I'll try that. I think I'm missing the drain line though, looked as if the drain would dump right on the valve cover. I'll grab a line out of the junk box. I picked up a new Carter lift pump tonight when I returned the fan tools I rented.
Old Apr 1, 2007 | 04:22 AM
PLC7.3's Avatar
PLC7.3
They came with a short rubber connector to the plastic drain then a very small steel line down the side clamped to the block..... about 12 inches.
Old Apr 1, 2007 | 09:54 AM
xjvince's Avatar
xjvince
thanks for the pic. my filter(napa3617) dont appear to have the bottom cap, looks like a one piece with the drain **** and elec. connector right on the filter itself. is this stock for a '94 or did somebody make a swap?? also what are each of the three elec. connections(2header/1filter)?? thanks
Old Apr 1, 2007 | 12:57 PM
PLC7.3's Avatar
PLC7.3
Header: side is Fuel filter plugged* (vacuum sensor), top black is fuel heater and bottom is the WIF* water in fuel sensor.... * if you ground these you should get a dash light. The heater comes on by an internal switch at 32*F wire is constant power....12V
Old Apr 1, 2007 | 01:51 PM
xjvince's Avatar
xjvince
just pulled my lift pump. the arm is pretty crooked. my new one is fairly straight. I've heard of the difference before, is this a upgrade or do I have the wrong part?
Old Apr 1, 2007 | 03:10 PM
Dave Sponaugle's Avatar
Dave Sponaugle
It is a new style pump.
Directions should be included with the new pump for proper installation.
