Injector questions
Old Mar 31, 2007 | 05:54 PM
evilhorde's Avatar
evilhorde
Injector questions
I have an '86 bronco 4x4 with a 351W efi. (not original, speed density)
I have nearly finished rebuilding the 351 and I am considering new injectors. Well I am going to get new ones but what options do I have?
The engine was balanced and has a comp cam (the speed density one that everyone gets. I forget the number right now.) It is also running a new set of dynamax headers.
What about increasing fuel pressure or using high performance injectors?
Any ideas out there?
Old Mar 31, 2007 | 06:44 PM
LxMan1's Avatar
LxMan1
The stock size injectors will work fine. You will have to reprogram the ecm if you go to larger injectors. I would run it as is and see how it does,
Old Mar 31, 2007 | 10:18 PM
Conanski's Avatar
Conanski
Unless you have aftermarket heads and intake, you don't need bigger injectors. Using other than 19lb injectors will cause severe running problems for the SD efi system.
Old Mar 31, 2007 | 11:37 PM
evilhorde's Avatar
evilhorde
Would spending extra money on performance injectors be money well spent? or does the speed density computer (and pressure limit) make this a moot point?
And thanks for the previous advice.
Old Apr 1, 2007 | 12:25 AM
Blurry94's Avatar
Blurry94
You can keep the stock 19's, even with aftermarket heads and a cam. Tuning options are limited for speed density, but if you have a local programmer that can work with speed density, then that'll be your best option.
Otherwise, an adjustable fuel pressure regulator (FPR), timing light and borrowed wideband (if you don't have your own) is another option for tuning.
The ECU will compensate some (with the stock injectors), but WOT is where you'll see the difference though...this is where some type of tuning is needed with speed density.
87beater
18
Apr 23, 2024 08:37 PM
jburke832
Aug 13, 2008 02:14 PM
kjg26
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Aug 17, 2006 05:37 PM
MORTORQUE
1978 - 1996 Big Bronco
Aug 14, 2004 10:29 PM
tstpnb
Aug 7, 2003 04:25 PM
