2000 Nav & correct spark plug
Old Mar 31, 2007 | 01:40 PM
Trucker22's Avatar
Trucker22
I'm about to replace spark plugs in 2000 navigator 5.4L. Serv CD says to use AWSF32P. At local store the motorcraft catalog says AGSF32PM (which I bought). Also at motorcraft.com both are shown depending on how you do a search. I cannot find a description of the difference and which is really correct.
Anyone know please? Thanks
Old Mar 31, 2007 | 01:42 PM
Trucker22's Avatar
Trucker22
Plugs
Forgot to mention the AGSF32PM is also known as SP493---not sure what the SP # is for the other plug.
Old Apr 2, 2007 | 10:27 AM
buzzard's Avatar
buzzard
I changed my plugs a few weeks ago and seems all the #'s have changed over the years. Go with whatever the books call for these days.
Old Apr 2, 2007 | 07:50 PM
thecardoc's Avatar
thecardoc
Well they are both correct for your Gator . But it all depends on which motor you have.
If you have a 32 valve motor you need the AWSF32P . And for the 16 valve motor you need AGSF32PM.
Old Apr 3, 2007 | 08:36 AM
Johnny Langton's Avatar
Johnny Langton
2000 models only had the 32V 5.4L.
JL
Old Apr 3, 2007 | 08:58 AM
Trucker22's Avatar
Trucker22
Plugs
I sure don't know which is right---the motorcraft catalog says AGSF32PM for the 32V Nav engine! I thought the 16V Expedition engines used a plug with the number 22 in it.
Guess I will have to call the dealer---I have not found anyone that sells the AWSF32P plugs--so I assumed the motorcraft catalog was saying the AGSF32PM replaced it.
Confusing to say the least
Old Apr 3, 2007 | 09:07 AM
Johnny Langton
2V 5.4L's use a colder heat range plug(the 22 is the heat range on the plugs) than the 4V engines(which use a 32).
JL
Old Apr 3, 2007 | 11:02 AM
Trucker22's Avatar
Trucker22
Plugs for 32V
Johnny
Great--that makes sense but that implies that 'thecardoc' in a note above is incorrect. So then is our best knowledge that the AWSF32P has been changed to AGSG32PM and that is the correct plug for my 2000 Nav with 32V engine, or do you know?
Thanks
Old Apr 3, 2007 | 01:19 PM
Johnny Langton
Johnny
Thanks
The 4.6L's use the 32 range plug,and the 5.4L's use the 22 range. 5.4L 4V's use the 32 range. I personally use the 22 range in my 4V Navi,and a colder 12 range in both my F150 and Tbird which are 4.6L 2V's.
JL
ElizabethRanee
Apr 9, 2016 05:33 PM
Lariat#1
Modular V8 (4.6L, 5.4L)
Mar 13, 2014 05:13 PM
jpalladino
1997 - 2003 F150
29
Jan 16, 2012 11:41 PM
ptf18
Oct 30, 2011 08:42 AM
m-cman
Jun 28, 2006 02:47 PM
